Sabaj A5 and A8 announced
Happyhammer
No, you do not want the volume knob at 12 o'clock because that hurts noise performance. I recommend setting the gain such that it is about 24 dB. With nothing connected play a 0.5 V test tone and use a DMM to measure the amplifier output voltage and set the knob so it is around 8 V. This will allow you to drive the amp to full power at the best noise performance.
EDIT: If you are using this on its own I would use the volume knob as that will truly give you the best noise performance. If you are using it like a power amp set the knob like I described above.
Michael
For those of us without the measurement skills. When using them as monoblocks, what's the approximate position of the volume knobs for approx 24 db gain? ie. 9,10,11 o'clock?
mdsimon2
Detroit, MI
MCH
Specifications
Inputs .................................................................................................RCA / XLR
THD+N ..................................................................................................0.005%
SNR ..........................................................................................................103dB
Channel separation .....................................................................................90dB
low pass cutoff frequency ...................................................................70~200Hz
Input Sensitivity / Input Impedance ............................................. 430mV / 22kΩ
Output Power
Stereo................................................................110W x 2(4Ω) / 66W x 2(8Ω)
BTL..........................................................................................225W x 1(4~8Ω)
Power Consumption ....................................................................................40W
Size ...........................................................................200X187X59mm (WxHxD)
Weight ........................................................................................1480g/ 3.26Lbs
Here is the info on the new 2022 A10a.
If you're interested in this, click the file.
no high pass version? wouldnt it be more useful for a wider audience? (just wondering)
spacevector
Bayrea
Does the input sensitivity spec of ~400mV mean that these amps will clip with normal sources like 1V Chromecast Audio or 2V Desktop DACs?
spacevector
Bayrea
There is a volume control for that.;)
True but if input to the amp is 1V, does it attenuate it enough to not clip? I thought the volume control only sets the gain of amplifier...
mdsimon2
Detroit, MI
I assume you are referring to the A10a? I can only speak to how the A8 works, which is that the spec’d input sensitivity refers to input sensitivity with volume position at maximum. You can safely use higher input voltages but you are limited to 1.6 V (unbalanced) and 3.2 V (balanced). It would be nice if they actually spec’d this because I had to determine it experimentally and honestly thought I could send it a 4 V input with a lower volume knob position without issue but this is not the case. I guess all of this comes with the territory of buying poorly documented Chinese products.
Michael
spacevector
Bayrea
Michael
Excellent - hopefully they preserved similar for A5. Thanks for the clarification!
Zek
Wrong, the amp gain is constant and depends on the design of the amplifier.
With volume control you adjust the amount of input signal to the amplifier.
Talisman
Milano Italy
@mdsimon2
Did you then conduct a blind listening test with the 252 hypex? They are very curious to have your impressions
mdsimon2
Detroit, MI
@mdsimon2
No, I have not. Was out of town on business all week and came back on Friday.
I plan on doing sighted level matched listening this week and will see if I think I can hear a difference. If I think I can hear a difference sighted I will get a speaker switch box and see if I can do it blind.
Michael
spacevector
Bayrea
After @mdsimon2 confirmed that the amplifier will not clip with a Chromecast audio (1V output), I ordered the A5 from Amazon US last week and it arrived this weekend. I paid $210 incl taxes.
Bought it to replace another chip amp that dies twice on me. The A5 works fine - hopefully this one lasts!
If I can get my other one repaired, I may send the A5 to amirm for review if he wants it.
ObjectiveSubjectivist
Europe
So while I'm waiting for a10d/a20d I put an order on two a8 just to test it. It's from Amazon so I'll be probably returning them as soon as new A10d/20d are out.
(Sorry for the cable mess)
Chuckv
San Diego
A8 arrived 5/8 from amazon. Left it on with no speakers until 5/13. Very warm to the touch. attached speakers today. no sound. metal piece sliding around inside. going back to amazon. too risky on quality. My Sabaj D5 is over 2 years killing like day 1.
Talisman
Milano Italy
I ask you a trivial question, did you check the rear input selector? if put on xlr and used in stereo it doesn't work
TheBatsEar
Germany
I think "metal piece sliding around inside" by itself is enough to just send it back. :cool:
However, i wouldn't say it's a QA issue, might just be a transportation problem.
I say try again.
Chuckv
San Diego
I discovered it the night I posted. You are correct. Thank you. I missed the selector.
Chuckv
San Diego
I say try again.
I just may. So many are getting problem free units.
mario_rouge
Michael
The blind test?
