How could it be any better than the reference design?Let s see if the Sabaj implementation is now better )
I'm not an expert but I see that PA5 has better performance than official tpa3251 TI datasheet.How could it be any better than the reference design?
We also saw RME beating AK4493 specs by short for example. Fine. But we are here talking about chip implementations VS all-integrated modules like IcePower, Ncore NC-MP and so on.I'm not an expert but I see that PA5 has better performance than official tpa3251 TI datasheet.
How does it possible?
So it's impossible...We also saw RME beating AK4493 specs by short for example. Fine. But we are here talking about chip implementations VS all-integrated modules like IcePower, Ncore NC-MP and so on.
how do you explain the differences in measurements between these two amplifiers that use the same module?We also saw RME beating AK4493 specs by short for example. Fine. But we are here talking about chip implementations VS all-integrated modules like IcePower, Ncore NC-MP and so on.
It is possible to make the performance worse - looks like the DIY amp has introduced mains supply noise, that is not on the Yamaha.how do you explain the differences in measurements between these two amplifiers that use the same module?
ICEPower 125ASX2 Class D Amplifier Review
This is a review and detailed measurements of a DIY amplifier based on ICEPower 125ASX2 module in Ghentaudio case. It is on kind loan from a member. The owner says the total cost is only US $220. I can't find the amp at the price he bought it so maybe it costs a few dollars more but still, it...www.audiosciencereview.com
Review and Measurements of Yamaha WXA-50 Streaming Amp
This is a review and detailed measurements of the Yamaha WXA-50, multi-function DAC, pre-amp, power amp, streaming and multi-room unit. It is on kind loan from a member. Even though it came out a few years ago (2016?), it is widely available. Amazon shows it costs US $478. Success of SONOS...www.audiosciencereview.com
could you suggest me a good cheap xlr cable? I would like to buy a Cordial cable with xlr Rean connector.It is possible to make the performance worse - looks like the DIY amp has introduced mains supply noise, that is not on the Yamaha.
See my answer above : how better "implementation" of any IcePower module would be a thing ? If so, it would imply some onboard modifications. I don't see this happening at 259$ for a full integrated amp. But I would be glad to be wrong.See what Topping did with the PA5 and TPA3251 chip.... It is better than the TI reference model ))) (thanks to their secret OP amps and high end inductors).
Probably a new implementation too for the A8 inside....
Different test settings (7 VS 24dB Gain), scales and bandwidths. The rest is on production margins of error (like variations we saw between same NC-MP modules), with clearly something wrong with one channel for the DIY review sample.how do you explain the differences in measurements between these two amplifiers that use the same module?
I use Cordial XLRs for measurements with my E1DA Cosmos. Not any difference measured to speak about against my reference Canare L-4E6S/Neutrik.I would like to buy a Cordial cable with xlr Rean connector.
Neutrik or Rean Neutrik?See my answer above : how better "implementation" of any IcePower module would be a thing ? If so, it would imply some onboard modifications. I don't see this happening at 259$ for a full integrated amp. But I would be glad to be wrong.
In any cases, both perform either worse or at best on par with datasheet to me.
If you want very good quality cables for cheap when compared to the overpriced audiophile snake oil, then go to a local Pro Audio Store (one that provides live P.A. service if possible) and ask for Neutrik nickel NC3MXX (silver pins) male XLR plugs and NC3FXX female XLR equivalent 3 pin plugs (about $5 each), you will need two of each.could you suggest me a good cheap xlr cable? I would like to buy a Cordial cable with xlr Rean connector.
Neutrik is Neutrik. I would have said Rean otherwise.Neutrik or Rean Neutrik?
Sorry, I believe REAN was a global brand from the Neutrik Group...Neutrik is Neutrik. I would have said Rean otherwise.
Thanks for that, they must be from the icepower data sheet, I'm not much good at deciphering these test charts, I can see the frequency drops about 3dB by 10khz and close to 6dB by 20khz this is beyond my hearing.The Bridge mode is only available when using the balanced inputs (XLR).
RCA = only for SE mode.
Maybe is a stack ICEpower 125ASX2 modules, size : 160x80x32.6 and the A8 is 200X59x208
Some measurements in BTL mode of the ICEpower125ASX2 module (source : Icepower)
clavier russe virtuel
It is. That wasn't imply otherwise. Neutrik products are Neutrik products. Rean are Rean ones (sure part of Neutrik group, but absolutely not the same offering).I believe REAN was a global brand from the Neutrik Group...
Post in thread 'ICEPower 125ASX2 Class D Amplifier Review' https://audiosciencereview.com/foru...2-class-d-amplifier-review.10442/post-1037824Thanks for that, they must be from the icepower data sheet, I'm not much good at deciphering these test charts, I can see the frequency drops about 3dB by 10khz and close to 6dB by 20khz this is beyond my hearing.
The top charts blue trace is intermodulation distortion I think ? looks reasonably low, the bottom charts are distortion vs power and noise ? I think, and I'm not clear on these,
Some help would be appreciated, how puch power, watts is produced before audible distortion kicks in, maybe instead of the traditional 1% lets say half that .5%, is that audible ?,
also is the 125ASX2 capable of a S/N ratio above 100dB A-weighted, if that is still a standard ?
I guess what I'm asking is, are these older and relatively cheap boards able to provide a sound that is hard to pick any difference when compared to the newer and better measuring offerings from the more expensive Hypex and Purify (obviously when not pushed into distortion).
Excellent, thanks for that,Post in thread 'ICEPower 125ASX2 Class D Amplifier Review' https://audiosciencereview.com/foru...2-class-d-amplifier-review.10442/post-1037824
