Schiit Ragnarok 2’s AP Report
dmac6419
USofA
Link
For $1500, only 100W into 4Ω is a bit disappointing; however, >20W into 32Ω headphones is just batshit (THX 789 is “only” 6W), though I’m gonna bet the output impedance is stupid high as it’s gotta be using the speaker amp.
Word,hope nobody gets electrocuted,after all it is schiit.
JohnYang1997
China
What?
2nd harmonic is under -120db at 32ohm 350mW
It's gonna be a good headphone amp. dc offset is 0.1mV.
Also it's basically a power amp, why would you think the output impedance is high?
M
MZKM
Land O’ Lakes, FL
What?
Also it's basically a power amp, why would you think the output impedance is high?View attachment 29778
Based on what Amir has measured in the past where they use the speaker amp for the headphones. I could be wrong, but there’s no data on it in the AP report.
JohnYang1997
China
? I can't understand what you are saying sorry.
Do you mean that speaker amp = high output impedance?
Or do you mean it's a bad speaker amp?
Or it's a bad headphone amp?
M
MZKM
Land O’ Lakes, FL
JohnYang1997
China
https://www.audiosciencereview.com/...-and-measurements-of-sony-uda-1-dac-amp.7586/
Again, I’m just assuming, as I see no way they can make a headphone amp that’s 24W into 33ohm. The Emotiva A-100 is able to do 12W into 33ohm when installing the included jumper to connect the speaker amp to the headphone output.
There is no fundamental difference between headphone amp and speaker amp. Schiit wanted to do it so they did it. Plus the dc offset is very low so no issue.
ra990
I just got this amp and I'm extremely impressed. I'm surprised more people aren't talking about it. It sounds amazing with my Aeon 2 and tower speakers. I have a Susvara on the way and this seems like it will be a perfect match. I think it's quite a value at the price point.
phoenixdogfan
Nashville
Link
You need g.t. 20wpc into 32 ohms for which headphone now? And which brand of hearing aid do they recommend when you accidentally have the volume control set to 5 o'clock?
I just got myself a fully loaded one today. Needless to say, the built in DAC feels horrible and completely unnecessary.
TheGhostOfEugeneDebs
I got mine last Friday and damn, pumping a TON of power into headphones seems to make a quite a difference. I got it because I was really unsatisfied with the way that the Emotiva A100 sounded when running my SR007 off it and I hated having to bring them into the living room for the nicer hypex monoblocks. The Ragnarok more than satisfies. It's got some coloration, similar to the way the Hypex amps sound when run through my tube preamp and I really like that.
Power Pop 23
FYI
I am currently seeing an Amazon USA listing for the 'Plain' version of the Schiit Audio Ragnarok 2 integrated amplifier in 'Silver' for $1,599 with a $300 digital coupon applicable at checkout, for a net price of $1,299. Schiit Audio is the seller and fulfillment is by Schiit Audio.
