I think they have designed this to create maximum internet forum column inches.
You need basic engineering quality for a TT. A unipivot arm is a way of side-stepping the need for high-precision (low friction but zero play) bearings but there's no similar option for the main platter bearing. You must have high quality there if you want to avoid rumble, rocking, and all the rest.
Yes, as did pretty much everything else at the time. The Valhalla board brought in a quartz-derived supply for the synchronous motor in 1982. It was still single speed, but it was the *LP*12. Singles were things you stacked on an autochanger.Even the basic Linn LP12 had a synchronous motor for a very long time. Don't know how it is today (EDIT: it is, the Majic PS still requires a pully to change the speed)
I don't understand what 3 mounting holes have to do with it?
There are a lot of "ready to run" TTs that come either with a fixed headshell and a pre-installed cart, or a removable headshell with pre-installed cart, usually something from the Ortofon 2M series or the lower end of the AT range.
Linn have long used 3-bolt mounting for their top arm and MCs, from the Ekos/Troika onwards.Are we talking about p-mount cartridges and arms? I'm not familiar with any of those. Or are there other arms and other cartridges with 3 mounting holes like the Regas?
Usually you have 2 slots on a standard mount arm and two holes on a standard mount cartridge, which gives you freedom to move the cartridge in each slot before tightening it down. 3 matching holes on the arm and cartridge nail down the alignment.
Do you have the name of a vendor that pre-installs a cart in a headshell? Sounds like the thing for friends that ask about this stuff.
Aside: am I the only person who thinks it's insane that there is still no standard for arm/cartridge mounting and geometry
I think the theory is that you want low torque so that minimal vibration gets to the platter but you need a heavy platter for speed stability which needs a lot of torque to overcome stiction and inertia so a nudge is what's required to fill the gap. The alternative is electronic control which starts with high torque and then automatically ramps it down as the required speed is reached.All the nottingham analogue decks required a push to get going, the AC motor cannot spin up the heavy platters. I've liked the sound of all the nottingham analogue decks I've heard.
They "might* have sourced good parts where they matter but until we see the measurements we can only guess.Right, which is why I'm skeptical about what the rumble / SNR & wow & flutter will be for the Sol.
I think in the UK any dealer will do that for you when you buy the TT or cart (maybe a nominal charge for the latter if's a budget one).Do you have the name of a vendor that pre-installs a cart in a headshell? Sounds like the thing for friends that ask about this stuff.
How many are there, and how do you optimise?Which geometry are you going to force on me?
And what if it's not what I like to optimize for?
I've thought the same, but getting things wrong seems to be part of the appeal of vinyl to many.Aside: am I the only person who thinks it's insane that there is still no standard for arm/cartridge mounting and geometry, so that any cartridge fixes precisely with 3, not 2, bolts*, guaranteeing correct offset and overhang?
I'd go for one chosen by experts who should be involved in defining the international standard, if such a thing was going to happen. If such a thing was done decades ago then part of the circle of confusion in mastering and playback would be sort of controlled by now.Which version of 'right', in terms of an alignment, are you going to standardize on?
They're all imperfect compromises.
A unipivot bearing allows the arm to rotate this way and that around the pivot axis, which has to cause a commensurate (and unwanted) stylus rotation within the groove. The most successful unipivots seemed to have been oil damped (silicon gunk), such as the Audiocraft, Formula 4, Kieth Monks (which used a mercury bath), and a few others.You need basic engineering quality for a TT. A unipivot arm is a way of side-stepping the need for high-precision (low friction but zero play) bearings...
Yes, indeed, and that's my point. Are you going to measure the inner and outer track radii of each record, factor in genre, and then realign the cartridge each time? Or even, if you have a "classical" session one day and a "rock" session on another, change it each time? And this bearing in mind the inherent distortion, inaccuracy of internal cartridge build, dust on records, dirt on stylus, etc.?Universal ones (i.e. not vendor-specific):
Baerwold
Lofgren
Stevenson
UNI-DIN
Vendor-specific:
Technics
probably some others I don't know
How does one optimize?
Pick where on the LP you want the most distortion vs least distortion. Or try to pick lowest average distortion. There is no right answer.
This is often related to the music genre, i.e. Classical often ends sides with big crescendos and complex passages, leading one to pick alignments that have the least end-of-side distortion. But for other genres, you may not want that.
