Scope probes
sergeauckland
Suffolk UK
I doubt your cheap probe can measure a rise time of less than 2 ns, which is what we're looking at here. The distortion is probably the result of interactions between the probe capacitance, source impedance, and PCB + probe ground inductance.
No, especially as my 'scope has a bandwidth of 40MHz, but what I do not understand, and that's my fault, is what's the point of this thread?
S
LTig
Europe
Found a better source: SPDIF output of RME ADI-2 PRO fs. Not terminated with 75 Ohm though, this may explain the ripples.
50 ns/div:
5 ns/div:
A risetime of 5.5 ns is not too bad. Still unknown whether the probe or the source is the limit though.
EDIT: spec of the probe is 1.75 ns risetime.
EDIT: same signal with same probe in 1:1 instead of 10:1, 50 ns per div:
Now we know why we should not use probes in 1:1 for high bandwidth signals.:oops:
D
Deleted member 2944
Guest
Scope probes can be a little confusing at times. When to use one....and when you don't need to......and how you can get confused by the results.
Dave has an illustrative video on this topic:
Dave.
mansr
mansr
Hampshire
50 ns/div:
5 ns/div:
How are you grounding the probe? It can make a big difference to things like those ripples.
LTig
Europe
The ca 10 cm long wire. You're correct, I should try something shorter ...
... done: using the supplied spring, 50ns per div and 5 ns per div, the ripples are mostly gone:
RayDunzl
Central Scrutinizer
Riverview FL
Why can't we use an electron microscope to see what the electrons are up to?
DonH56
Monument, CO
I thought about digging up a shot from work showing <20 ps edges on a 70 GHz DSO, or the edges from one of our 30 GHz (slow) dif probes, but then remembered this is an audio forum...
NTK
US East
This probe?
mansr
mansr
Hampshire
Sounds expensive.
DonH56
Monument, CO
DonH56
Monument, CO
Sounds expensive.
I don't remember the cost of the tri-mode probes, think ~$20k to $30k each.
I've said before I can check out a DSO (with or without probes) and take it home to play, but balk at taking home a 'scope worth more than my home.
mhardy6647
Too lazy to read? It's written at the bottom of each screenshot: 24.5758 MHz.
Derp. Sorry.
I saw that, but misinterpreted. :(
I guess I was thinking/wondering/assuming it was an audio-frequency square wave, and I was pretty disillusioned to see expensive probes (or even cheap ones) struggling to reproduce it (umm, I guess, transfer it would be more apt).
sergeauckland
Suffolk UK
Derp. Sorry.
I guess I was thinking/wondering/assuming it was an audio-frequency square wave, and I was pretty disillusioned to see expensive probes (or even cheap ones) struggling to reproduce it.
I missed that too, but my excuse is that I've never used a digital 'scope, so those numbers at the bottom meant nothing to me. My first 'scope was a Cossor 1049 with a 100kHz (not MHz or GHz) bandwidth, http://www.thevalvepage.com/testeq/cossor/1049/1049.htm so even my current 40Mhz 'scope seems advanced.
S
