Just got another pair, tried several of the autoeq presets just to revisit them. I'm sticking with Amirm's settings but without the big bass boost to use for both gaming and music. Not that bad to power well, tried first with the SMSL C200 and it was ok, but using it as a DAC and kicking in the SMSL HO150X was a big difference. Just using the single ended cable since it's the same power on both plugs, will test the 4.4mm for function later. They really do benefit from tweaking, they sound finished now compared to out of the box. I'm in mid gain at 2 o'clock for fun loud but not dangerous using a -4db preamp reduction. Anything with 3 watts into 32 ohm will have all the power you need without having to use high gain. This week I'm going to have some fun with the SMSL DO400 as a 5 volt DAC into a Topping A90D, and also have a Soundblaster AE-9 with no control module (which has the amp in it) and will run RCA out into the HO150X just to have fun with the virtual 5.1 surround playing Destiny 2. I have the HD700 to compare it to, but the HD650 sold last night. A Thieaudio Ghost here is really close to the HD600/650 so might compare it at the same time. Had these a few times over the years, nice to hear they're just as nice as I remember them being (with eq).
