You do understand that Watts is talking about numerical precision as measured in the digital domain only, not anything analog?Whenever Watts' -300 to -400db claim comes up, I'm reminded of this scene
Does that matter? He claims it’s audible, so whatever it does should then also be embedded in the analog signal somehow.You do understand that Watts is talking about numerical precision as measured in the digital domain only, not anything analog?
It might matter because he said he doesn't know why its audible. IOW, it could be that whatever is audible is correlated with the calculational precision. Watts likes to use very long digital filters. In that case, or for other calculations Watts may be doing (perhaps for his 17th order modulator) numerical errors may accumulate merely because of the large number of calculations. If using 64-bit math actually does turn out to sound better than using 32-bit math then it could be due to accumulated errors.Does that matter? He claims it’s audible, so whatever it does should then also be embedded in the analog signal somehow.
He didn’t even really prove that it’s audible at all.It might matter because he said he doesn't know why its audible.
Just to be sure, Rob the atomic clock claims there is no limit to how accurate smalls signals needs to be, and that this explains why pure copper cables produce better depth perception and presumably better soundstage. Here is a screen shot of his slide. You are claiming there might be some truth to this? I would love to understand better.It might matter because he said he doesn't know why its audible. IOW, it could be that whatever is audible is correlated with the calculational precision. Watts likes to use very long digital filters. In that case, or for other calculations Watts may be doing (perhaps for his 17th order modulator) numerical errors may accumulate merely because of the large number of calculations. If using 64-bit math actually does turn out to sound better than using 32-bit math then it could be due to accumulated errors.
Its not unheard of for such problems to occur in some cases. One randomly selected paper in the general subject area: https://arxiv.org/html/physics/9807003
By the way he also claims his 9 year old son could tell the difference between a 120db DAC and 150db DAC while watching Shaun the Sheep on TV. If you have any explanations for that, I'd love to hear that too.It might matter because he said he doesn't know why its audible. IOW, it could be that whatever is audible is correlated with the calculational precision. Watts likes to use very long digital filters. In that case, or for other calculations Watts may be doing (perhaps for his 17th order modulator) numerical errors may accumulate merely because of the large number of calculations. If using 64-bit math actually does turn out to sound better than using 32-bit math then it could be due to accumulated errors.
True. But that doesn't mean the claim is automatically false either.He didn’t even really prove that it’s audible at all.
Maybe he was measuring the wrong things? Sigma delta DACs have dynamic distortion/noise effects that don't occur in other types of audio gear. What looks like noise on an FFT can be a non-PSS deterministic signal that sounds ugly. It may take some review of how DFTs work to see how that can happen, although to put it in simple terms a non-PSS signal changing over the time an FFT is acquired may have its energy spread across bins. Thus it may not appear as a distinct spur. Not sure if Watts was measuring everything that could be measured when he described the dacs his son was said to be able to discriminate.By the way he also claims his 9 year old son could tell the difference between a 120db DAC and 150db DAC while watching Shaun the Sheep on TV. If you have any explanations for that, I'd love to hear that too.
Since nobody has demonstrated otherwise since the release of the products, I think we can be quite confident regarding the audibility.True. But that doesn't mean the claim is automatically false either.
That really is a collection of nonsense. I wonder if he believes it.Just to be sure, Rob the atomic clock claims there is no limit to how accurate smalls signals needs to be, and that this explains why pure copper cables produce better depth perception and presumably better soundstage. Here is a screen shot of his slide. You are claiming there might be some truth to this? I would love to understand better.
What to do? Believe something that is ridiculously unlikely and that he hasn’t actually demonstrated? Or defer to the microscopic possibility that it might be true and shift the burden of proof to others?True. But that doesn't mean the claim is automatically false either.
That's our job, apparently. I mean, Galileo made somebody else prove his conjectures. All great science works that wayThe people who are extremely confident about these things never go out of their way to prove them.
Did you watch the video in which he makes these claims?Maybe he was measuring the wrong things? Sigma delta DACs have dynamic distortion/noise effects that don't occur in other types of audio gear. What looks like noise on an FFT can be a non-PSS deterministic signal that sounds ugly. It may take some review of how DFTs work to see how that can happen, although to put it in simple terms a non-PSS signal changing over the time an FFT is acquired may have its energy spread across bins. Thus it may not appear as a distinct spur. Not sure if Watts was measuring everything that could be measured when he described the dacs his son was said to be able to discriminate.
I think he believes it's the only card he can play to distinguish his (and let's not fanny around saying he has no stake other than consultants fee in Chord DACs, they are his ) products from any other competent DAC.That really is a collection of nonsense. I wonder if he believes it.
Well, he got people on the internet to harass us about it. So that's success. I guess.I think he believes it's the only card he can play to distinguish his (and let's not fanny around saying he has no stake other than consultants fee in Chord DACs, they are his ) products from any other competent DAC.
Personally I choose to believe in the teapot.What to do? Believe something that is ridiculously unlikely and that he hasn’t actually demonstrated? Or defer to the microscopic possibility that it might be true and shift the burden of proof to others?
Hmmm.
