None of those will be any better than a Wiim Pro Plus at $220.
It will also require a monster of a DAW (Digital Audio Workstation) to handle very many tracks at those crazy high sampling rates for no extra benefit. There is benefit to 24 bits and maybe up to 96khz, but going over that will bring most PCs to a crawl. 24/48khz is plenty when working on recorded tracks.
There is no benefit to higher than 16/44.1 for playback after the other work/mixing is done.
Edited to define DAW.
Are you joking? It exists a 25.000 $ DAC?
Quite right,None of those will be any better than a Wiim Pro Plus at $220.
There is a difference in recording and processing too. Lots of VSTs benefit from oversampling internally and the latest DAWs run at 32bit floating point (at least). I suppose it's a bit analogous to old tape or something, a little bit of noise/hiss matters if you have 80 tape machines running.
I think you could probably make an argument for running higher bit/sample rates if you are doing some processing on playback. I'd argue that 12 bits would be inaudible in most cases. And 13 bits is twice the size of 12 bits.
Apparently there are still a lot people with enough money around to fall for this crap., fools and their money...There was a DAC posted here (for a laugh) that cost about 150,000 USD, and you then had to buy a power supply and other bits I couldn't get my head around for about the same again. I think the power supply was 75k or something.
I thought it was like buying a car for 1,000,000 and then having to buy the engine and stuff.
It isn't the bit rate (32 vs 28) that brings a DAW to a crawl so much as insane sample rates (over 96khz). More than 96,000 samples per second with each sample requiring a 32 bit float is a ton of unneeded data.
24 tracks of audio captured at 768,000 samples per second at 32 bit float? That is over 18 million 32 bit float (4 bytes each) values per second to process and playback simultaneously. Complicated processing on ~72 million bytes per second. Really hard to do in real time. Overkill for no benefit.
Quite right,
The only things that MIGHT be better with these Uber expensive DAC's is built Quality, durability and reliability over a longer time, perhaps product support as well, however even that is not always a given.
As for performance, well, they seldomly perform any better than a 200$ DAC , and in many cases worse or slightly worse, see the many reviews here.
So basically you pay for better looks and/or materials (subjective of course!) and some bragging rights, but not much else.
anyways 25.000 for a DAC is criminal!, speakers perhaps, but electronics that were essentially perfected some 30 years ago (when well implemented)...
Yeah I agree, my old laptop struggles massively with ableton sampling rate above 48k. Doubling the sampling rate chokes the system by more than double, I go from being able to have many tracks all generating in real time to struggling to get 2 going without jitters.
PS. I suppose I can't really change the bit rate to compare the difference.
Really hard (impossible) to get a good mix if you can't hear all the tracks and effects played back together in real time.
Ha ha, yeah. I actually like the idea of having it too high to stop the constant tweating and as a sort of restriction. The two guys my username is making a nod to, had a prophet synth, 2 plate reverbs, a digital FX unit, an old phaser pedal, and I suppose some other stuff. Whereas I can (thereotically) use the same VST 1000 times, with the PC grinding I am restricted like I would be with my guitar and some pedals.
There is a lot of chasing of "analogue sound" but I think what people want is a bit more "analogue workflow". Apologies for using the term workflow.
I hope I did a good decision with my Genelecs 8030 1100€ the pair, for my modest budget.I don't even think any speakers are worth $25,000. Above about $5000, you are paying for looks (usually bad), weight and size, more than sound quality.
Analog "workflow" can really suck. With my first band in the early 80s, we only had two cassette decks and a crappy mixer. Had to build up tracks by playing along with the first deck while recording on the second and then reversing. Terrible sound and it took forever. I am happy with all digital now.
For sure, and I think recording stuff is entirely different. Digital workflow when you are generating all the sounds in real time (can) leave you with so many options and very little recording or commitment. I have very little interest in recording a live mix to tape and editing, but I think there is something better about editing the mix on a computer as if it were a tape recording, rather than tinkering with automation envelopes.
I suppose I am probably sympathetic to the idea of analogue sound, when it comes to synths and 'airless' stuff. Similar to subtly randomising midi velocity/swing to humanise, I'll add volume and frequency modulation at random rates dialled back to a point where I cannot hear it in order to give some "life" to stuff. Or turn off the sync for the waves on the synth. Such stuff also sounds better to me with an artificial noise floor, which is probably sacrilege to say on here but I'll mention it.
Many DACs descriptions enhance in capital letters 32/768 kHz resolution. Is there any domain when such a resolution may be justified?
Bah, the gray moth… my ultrasound echograph uses 1.500.000 Hz and I perceived it (sarcasm).Can you think of a circumstances where you'd even want a dynamic range of over 190dB and/or a frequency response up to 384kHz?
Apparently the Gray Moth can hear up to about 300kHz (gotta get away from those bats with that pesky echolocation thing), so there is that to consider if you want to record those sounds, but otherwise it doesn't seem to be useful for listening to music.
I hope yes!@Brian Hall I think you should add an ultrasound echograph to your new symphony. Behringer surely make a cheap one.
Thanks a lot again for all members that had the patience to persist on changing my perception on dacs and human listening.
