- Joined
- Mar 1, 2016
- Messages
- 816
- Likes
- 1,668
I absolutely love the sound.
In my opinion, for $2,700 you get a $10,000 Dac.
The reviewers are gushing over it.
Jim,Competently designed electronic - especially DACs - have no "sound". If you love what you hear, you love the music, not the circuitry.
For $2,700, you get ripped of by at least $2,000. Peruse the review results for Dacs here , and you'll see what I mean.
Just because delusional marketing people gush over something doesn't make it of any greater value or utility. The way to evaluate an electronic device is: 1) Run a suite of tests and measurements. This will tell you what it does. 2) Compare it to other devices with similar levels of performance on the market. This will tell you what it's worth.
Believe me, there's no DAC that has a competitive market value of $2700, much less $10,000.
Jim
As a fellow R26 owner I’d be interested in which areas you find the LAiV better and vice verca. I think the R26 is fantastic but I do have my views on where its weaknesses lie, in particular compaired to my (significantly more expensive) Vinyl and CD sources.I'm comparing the LAiV Harmony to my Gustard r26 r2r Dac which is no slouch. To my ears, the LAiV sounds better. Confirmation bias? Maybe. Time will tell.
Well, that or you simply stating whether your tests were blind or meaningless.Confirmation bias? Maybe. Time will tell.
Jim,
I'm anxious for Amir to review one. I'll leave it up to you to send one in to him. I have a bit of knowledge in this area as I'm an electrical engineer and patent attorney. I've been doing this for 60 years so I also have a little experience. In theory all amplifiers are wires with gain and all D to A converters are 100% accurate so completely neutral. Then the real world intrudes. I'm not one of these people who buys cables braided by virgins but there sure are component differences. I (and most everybody else) can tell the difference between an AKM chip and an ESS chip and more particularly R2R ladder Dacs. They all have a different sound regardless of noise or frequency response measurements. Perhaps it's the harmonics but they definitely sound different. I agree with you that the usual suspects hype the latest bling and we all should be very skeptical of their reviews. I'm comparing the LAiV Harmony to my Gustard r26 r2r Dac which is no slouch. To my ears, the LAiV sounds better. Confirmation bias? Maybe. Time will tell.
YMMV.
StandardModel
I have two alternate inputs to the Dacs. First is my Rose HiFi RS 130 and the second is a Bacch4Mac digital processor patented by Princeton University and marketed through Theoretica Applied Physics. They are both interesting inputs with very different sound. I'm addicted to two features. The first is sound stage (height, width and depth)and the second is accuracy of reproduction meaning the conversion has to be able to handle frequency transients very, very quickly. Neither of these are easy to do electrically. In theory it's easy you just have an infinite power supply and you can get completely vertical transients. In the real world, these things don't exist. Everything is a compromise for cost, etc. Just ask the "value engineers". After all isn't a Toyota the same as a Lexus? A $500 dollar Dac might be good and a $2,700 Dac might be bad but the bigger budget gives the designer a lot more options to achieve a good result. For me the difference is in accuracy and clarity.As a fellow R26 owner I’d be interested in which areas you find the LAiV better and vice verca. I think the R26 is fantastic but I do have my views on where its weaknesses lie, in particular compaired to my (significantly more expensive) Vinyl and CD sources.
Chacun à son goût.If you can identify differences in a rigorously controlled double-blind test to a statistically significant degree, then those differences exist. IOW, they are above the threshold of hearing. OTOH, if you cannot identify those differences to a statistically significant degree, then they do not exist; IOW, they are below the threshold of hearing.
Neither beliefs nor simple assertion constitute proof, no matter how desperately we desire to believe otherwise.
This video provides you with the necessary information on double-blind testing.
Jim
Foe me the difference is in accuracy and clarity.
Chacun à son goût.
The reviewers you list are gushing about just anything they receive for review.The reviewers are gushing over it.
Doesn't make a lot of sense. Especially when there are absolutely terrible 10k$ DACs out there and perfectly fine 100$ ones.In my opinion, for $2,700 you get a $10,000 Dac.
What that supposed to mean ?Chacun à son goût.
What on earth are you talking about? You don't need to do any such thing. "vertical transients" is a nonsense phrase - any real world signal is band-limited. It just needs to be "vertical" enough, and in electronics terms, the highest frequencies humans can hear are glacially slow.the second is accuracy of reproduction meaning the conversion has to be able to handle frequency transients very, very quickly. Neither of these are easy to do electrically. In theory it's easy you just have an infinite power supply and you can get completely vertical transients
It means each to his own taste.The reviewers you list are gushing about just anything they receive for review.
Glad you're satisfied with your purchase, but, again, let's see how this would perform on the bench !
If you don't know what a vertical transient is then you haven't spent much time in front of an oscilloscope looking at square waves.What on earth are you talking about? You don't need to do any such thing. "vertical transients" is a nonsense phrase - any real world signal is band-limited. It just needs to be "vertical" enough, and in electronics terms, the highest frequencies humans can hear are glacially slow.
I have yet to get an answer when I ask if DAC's have improved since they were introduced in 1983?...also do all DAC chips sound the same?
