Shakti Hallograph's, are you a believer??
D
Deleted member 12
Guest
Well a few sticks poking into the air will respond by resonating when excited by the music at frequencies depending on the stick's mass, stiffness and dimensions. If you prefer this extra bit of sound being added to what is coming out of your speakers, bully for you. What it is not doing is changing the room acoustics.
Really, if it is making a change to the sound in the room and is doing so non-electrically, what is it doing if it is not changing the room acoustics? Please read my OP. I know that you have heard these in your system, right...??
D
Deleted member 12
Guest
'Gullible fool'.
Ok, so you are telling me that you have listened to these and they made no difference in your system...none. If so, then that is your opinion and I accept it. OTOH, IF you have not listened to these and are doubting me because they look like they cannot work. ( which indeed they do...to some) then the 'gullible' might apply to you, no??
I noticed you are a Grand Prix dealer...a product that I use and happen to like..... a lot. However, the addition of the Formula shelf to my system ( replacing the standard acrylic shelf) made absolutely no difference to the sound...none!! So, I ask you, are you a "Gullible fool" for hearing something from that mod in your system; or at your dealership???
Keith, perhaps---just perhaps, before we post an opinion on something that we have not heard, it makes sense to get off our duff and go out and listen for ourselves. An unacceptable concept to many members on this forum it would seem. I'm done here.
Purité Audio
Industry Insider
Barrowmaster
London
Dealers laugh behind your back, and they will whisper quietly between themselves ' here comes that gullible fool' and wonder expectantly what rubbish they will be able to sell you today.
Frank Dernie
Oxfordshire
Obvious trolling is obvious.
Thomas savage
The Watchman
uk, taunton
Keep on thinking like that. In this hobby, you are going to deprive yourself of a lot of music and a lot of pleasure. I would suggest putting cotton wool in your ears from now on...after all, you don't really need them do you, LOL.
Given the grotesque amount of self indulgence in 'this hobby' ( your hobby not mine, I'm more interested in how things work, design and engineering etc oh and listing to music not obsessing about some wavy stick or fuse wire) Depriving oneself in this context might be seen as a good and healthy thing to do...
Maybe you should try it..
I'm off to see joe bonnamassa at the Royal Albert Hall Friday , no wavy sticks though so possibly we won't be hearing the music as it was intended..
Thomas savage
The Watchman
uk, taunton
No, I think they too believe...
I'm sure the maker of these wavy sticks believe they work too...
RayDunzl
Central Scrutinizer
Riverview FL
Shakti makes another product called a stone...take a look at it on their web page, do you doubt that works as well???
I looked at their EMI test:
Lay a Shakti Stone on top of a log-periodic antenna and measure a reduction in signal strength.
They did not provide a control. Perhaps an old steel-toed boot would perform as well, or even better. I have two of them for sale, if your skepticism and open mind makes you want to try them out.
http://www.shakti-innovations.com/emitests.htm
Maybe if they had placed one on a piece of equipment I might have in my system and provided some measurements of the output change, it would make more sense to me.
Purité Audio
Industry Insider
Barrowmaster
London
They 'believe' one is born every minute.
Sal1950
The Chicago Crusher
Central Fl
Some maybe, but a couple I'm personally friends with up in Chicago used to laugh and joke with me when I'd stop in. Regalling stories about the audiophool that spent $------------------ on some snake-oil product he sold.. (and his profit margin) . LOL
Blumlein 88
Yes, and before he thinks the steel toed boot is a crazy idea how could he possibly have an opinion until he listens and gives it a try.
Blumlein 88
Why would be look at those and read the white paper and not bother trying? How about an alternative product. Diffusion panels. You could look at the odd shape and be told they make quite the difference, and think "bah....looks like some bad artsy wall treatment to me". The explanation of how it works however is in accord with the regular known properties of sound and nothing mystical or magical. Plus they can provide measurements showing the change.
The product you are so fond of, have experienced, well it appears by known properties of sound propagation to do nothing of the sort claimed. Their white paper explanation is a fairy tale woven from imagination. It simply offers no likely reason it works except psychologically by hitting on the regular prejudice of people like you who think everything works and hears it.
On top of that as someone else mentioned. Even were it to work the price vs what you have there is obscene. You could take pictures from about 3 angles and go make an exact duplicate for far less money. So even if it works you are being ripped off.
Mivera
West Kelowna
Look deep into my eyes ------------------------------:eek: :D
Is that Cat Stevens? Looks like he's wacked right out on strong acid.
Speedskater
Cleveland, Ohio USA
Why are some audiophiles so quick to believe alternative reality science and engineering? If we place large diffusion panels or bass traps in a room, the differences can be measured and heard in blind listening test. Then we can discuss whether the panels or traps are an improvement or not.
With alternative reality products there are no significant measurement differences or blind listening test differences.
Speedskater
Cleveland, Ohio USA
About the Shakti Stone tests,the log periodic antenna was used from 300 MHz to 2 gHz, this is in the RFI not EMI range. But it's not 'Interference' if it's the intended signal. But in any case, how an antenna is affected has nothing to do with acoustics or shielding audio products.
watchnerd
Seattle Area, USA
I use a set of the The Hallograph on top of my iPad Air -- you wouldn't believe how much better it makes my Roon streaming server sound when controlling from the iPad!
