Mossshine
- Joined
- Feb 13, 2021
- Messages
- 16
- Likes
- 5
Hello, I would like to ask for some advise for "balancing/clearing audio signal" (can't describe it better).
I get that "good old" electric fuzz, mainly when under load. This gets better (but still present) when I literally take copper wire, put it under one screw holding the motherboard to the case and grounding the other end to the outlet (EU). I had different motherboard before and it was even worse (surprise surprise, shielding is better on rather expensive motherboards). I did try unplugging other stuff from PC, like peripherals and having only pc, monitor and amp in the outlet, but no luck.
Is there anything I can do to fix it, other than making it less annoying with a cable sticking out of my case ?
Audio setup:
From Windows 10 and MusicBee (ASIO or WASAPI shared) player,
to SMSL Sanskrit 10th MKII DAC via single USB cable plugged from the back of my motherboard,
then taking nice and chunky RCA cables to DarkVoice 336 TubeAmp,
outputting to my DT-990 PRO 250ohm.
PC:
When DAC is plugged to my phone, no more fuzz comes out, which means, it's really coming from PC.
Audio setup:
PC:
- ryzen 3600
- asus x570 tuf
- amd rx 470
- 2x 8gb ram corsair
- 4x hdd
- 1x samsung m.2
- evga SuperNOVA 850 G3
- no other pcie cards
