Short RCA Interconnects
restorer-john
Not a fan of any of the modern flippity floppity connectors starting with the ole RJ11 phone jack thru RJ45 Ethernet and HDMI.
Totally agree- they are terrible connectors. But my personal least liked were the 'Din' speaker plugs, round Dins (up to 8 pins) and the crappiest one of all- the SCART plug. That thing was hideous.
trl
King of Mods
Iasi, RO
I'm using Amphenol RCA plugs myself since few years, never had an issue, strongly recommended.
Wombat
Australia
Pro is the go. :)
Dismayed
Boston, MA
You really are not a fan of Schiit...
Maybe I'll just buy some connectors and cable to make my own. It looks like the cost is about $15 to make 4 x 6" cables and connectors.
Fandom has nothing to do with it. Some opinions are based on actual experiences.
Rollingsound514
Montreal, Canada
Holy thread revival, but if one was inclined to buy and not build their own cable... where does one go? the Monoprice ones I got have these massive connectors that don't fit well side by side, it's a weird design flaw. I have a pair of the Schiit cables but don't want to give them more money...
Blumlein 88
https://www.monoprice.com/product?p_id=653
You could get the really cheap monoprice RCA cables above.
https://www.proaudiola.com/product-p/1-m2549-rca-rca-1.htm
These have nice Amphenol ends on Mogami cable. Not the thinnest, but look to be a bit thinner than the monoprice cables. You can look at the picture close ups and see what you think.
Cape Town, South Africa
Some might argue that these are all one needs:
I've used these previously in various applications and have had no issues whatsoever for my two and a half bucks.
That said, I currently use custom made interconnects with Sommer Stage 2 AWG24 and the identical Amphenol plugs pictured in the above posts.
I cannot speak for anyone else, but these seem to do the job for me at very reasonable cost.
And no, even with my highly resolving headfi rigs I can hear no discernible difference between the two types of cable.
Sal1950
The Chicago Crusher
Central Fl
I've used those Monoprice premiums throughout my 5.2.4 channel rig and have had no issues with them. For the money the plugs seem to be of very high quality with just the right balance of thickness and tension of the ground circuit leafs to give good long term connection without being too tight going on/off that scares you that something internal might be damaged.
Krusty09
neutrik rca make nice connectors and a fair amount of bare cable to make your own. Good stuff and pretty cheap too.
esm
Berkeley, CA USA
I'm firmly in the "cables are cables, get the cheapest you can live with the aesthetics of" camp, so this is a weird post for me to make:
I have a bunch of these specific cables (because they were $2-3, who's going to say no to that?) in a variety of lengths, and I've had nothing but trouble with them. With most of my equipment, the sleeve isn't tight enough, leaving a very loose connection. That's not the end of the world, because looking at the image you can see that the sleeve actually appears to be a series of six separated sections (like many RCA connectors), so one's first inclination might be to just squeeze a couple of opposing sections tighter to increase clamping force.
That would be a mistake, as you'll quickly find that they'll snap right off, revealing that the pretty plating is hiding a highly porous metal underneath, presumably cast. Congratulations, you've discovered at least one source of the low price.
tl;dr: the cables are fine, the connectors are terrible. I became a bit more discerning about my RCA cables after dealing with these.
Timbo2
USA
I have no problem making my own, but couldn’t by the components for UD$9.00.
https://www.ebay.com/itm/291536688674
I’ve been using them for about a month with no issues. Measured them with a multimeter, miminmal impedance and the plugs grip firmly. Thumbs up!
Sal1950
The Chicago Crusher
Central Fl
That's curious? I've owned many, many cables over the last 50 some years, including some quite expensive Kimbers, AQ's, and others with the Mono's giving me one of the best OTB fitments I've experienced. Maybe the gear you've attempted to use them with were made to slightly undersized dimensions, or mine are oversized? In any case good cables can be obtained without spending a large amount of money, folks may just need to find those that are best sized to their gear.
GGroch
Denver, Colorado
I have bought about a dozen short (7 inch and 1 Foot) cables from Ghent and they have been cheap (Less than $15) and good quality. They have a lot of choices including some that are thin and flexible so as not to move push around lightweight components. This is where I go for short pre-made cables now.
Here are some of their offerings.
The downside is typical slow economy shipping from China. They have arrived quicker than promised, but not quick.
rcstevensonaz
Reviving an old thread... but, some follow up questions that fall within the original topic:
Q1) Is there a recommendation on type of cable that works best for short distance RCA interconnect — e.g., when an E30 DAC is sitting right on top of an L30 headphone amp? I assume capacitance is not really a factor at this short of distance. But, cable flexibility can be a big problem since the U-bend is tight and the units are relatively lightweight.
Q2) Does the answer for type of cable change if the DAC / Headphone are in an electronically noisy area? E.g., on a desktop with laptops, monitors, external docking stations, and other electronics sitting right next to it?
For example, I find my short LC-1 Blue Jeans Cables to be very stiff and wanting a larger bend radius; though I can use a velcro tie-wrap to tension the two sides of U-bend well enough.
But, I was looking at options from Worlds Best Cables (WBC) and wondering if a star-quad Canare L-4E6S or one of the Mogami cables would be better suited for a short interconnect between the stacked devices. And especially since they use the long Amphenol RCA connectors.
Doodski
Have you tried applying some heat to the cable to make it malleable and then when it cools it will set in that shape? A hair blow dryer, stovetop heat etc etc.
617
Somerville, MA
Ironically I find cheaper RCA cables are more flexible. Here's what I would do - get a single 6' RCA cable which is not super stiff. The ones with the braided insulation would be a good bet, they tend to be very flexible. Get four Neutrik/REAN connectors (see picture, parts express sells them). Cut up the cable and make your own connectors. Amphenol is another good brand but I prefer the look of the Neutriks.
Regarding your questions:
1. Thin RCA cable is fine and the thick cables just have more insulation. I hate thick RCA cables, I really do.
2. Not really, all of these cables are shielded and I don't think you'll see any differences in performance. If you have problems you'll want to do a balanced set up, provided your equipment is balanced. I get residual noise from my graphics card but it isn't picked up by my cables I don't think.
