Should an amplifier (NAD M33) be completely silent?
JktHifi
But in most (all?) cases of the M33 it is not. I checked for my own unit and another out of the box. If nothing is connected to the unit, a few moments after turning on, the noise starts from the unit itself. Of course on a grounded power supply line.
Many owners of the M33 verified this in this thread and others.
Is the Class D amp prone to electricity? The NAD M33 use class D amp from Purifi, right?
voodooless
Netherlands
It's just my suspicion. The user must handle it with care.
I still have no idea what your talking about or what your are suspicious of. So again, what does “prone to electricity” mean? Be concrete, be precise, be concise!
fpitas
Northern Virginia, USA
Maybe he means ESD?
Sal1950
The Chicago Crusher
Central Fl
The worst part as I see it, is that NAD won't look into the issue for customers of this fairly expensive
product. I don't know but do the Class D amps being built by our friend at Buckeye Amps have these issues? Is it a NAD thing or a Class D thing? I've read a lot of the Buckeye amp threads but surely not all of them. Just Curious ???
Doodski
All switch mode PWM (pulse width modulation) power supplies are prone to this issue but most of them don't whine, hiss or buzz. I've repaired thousands of PWM power supplies and I replaced maybe a dozen toroidal transformers. So not as common in good quality PWM power supplies.
It's neither. It's a switch mode PWM power supply thing.
Sal1950
The Chicago Crusher
Central Fl
True but from what you say above it is a bit of a NAD thing as some component either as a result of poor build quality or board design has the propensity to sing. Bummer as it should be a problem that
is addressable.
vco1
The hum from my Cambridge 840A was so bad that I replaced it. A pity, cause there was nothing wrong with the amp, apart from that unbearably loud hum/buzz from the toroidal transformer.
As for OP's question: should an amp be silent? In my humble opinion the answer to this questions is Yes. In practice though it seems it's hard to control.
Sidenote: I never had this kind of humming with the cheaper amps I owned. More expensive is not always better in this regard.
JktHifi
Prone means: (from google translate)
[adjective]
likely to or liable to suffer from, do, or experience something, typically something regrettable or unwelcome.
