nzgfs
- Joined
- Oct 16, 2021
- Messages
- 8
- Likes
- 11
When I use the Apple USB-C to 3.5mm headphone jack adapter in Windows, there is an "enable audio enhancements" button in the audio settings, with the text "allows extra signal processing by the audio device". What does this "signal processing" mean? Does it just add some unnecessary sound effects or something? What will happen after enabling audio enhancements? Will it make the sound better or worse?
Update: What about the new "Enhance audio" switch in Windows 11 sound settings? The description below says "Automatically improve sound quality (turn off if you experience sound issues)". Is it the same function as I mentioned above? Or does it really do some extra processing on the sound? I didn't find any documentation about this on Microsoft website.
