I am using the Sennheiser HD 650.
I currently have two setups:
1. Topping E30 DAC + Douk U3 Amp ($40 on Amazon)
2. TempoTec Sonata HD Pro II
I can't really hear any difference in sound quality between the two. If anything, I think things may sound better using just the Sonata (I think my Douk amp may be faulty).
My question is: Would I notice a difference if I got a better dedicated amp (like the JDS Atom) and paired it with either the Sonata (then used as DAC only) or my E30? Or will the Sonata provide all the power necessary to get the most out of my 650s?
