Show us your Cars
Juhazi
Finland
It was in the link I posted. Torque may be present with a non-rotating motor, but power is 0, because the rotation in equation is 0. When it starts moving/rotating, power "happens"
This discussion started from driveability and aggressiveness of certain engine types. Torg/power curves are done at full throttle on dyno and they tell the maximum capacity of the engine. However, outside racing we hardly ever push gas pedal down and hold it there for even tens of seconds. How a car or a bike feels at normal everyday cruising, comes very much from max torq/power at low rpm and throttle response. Throttle response is determined by valve timing, injection and ignition control, intake/exhaust port control etc. modern "black box"programming (and gearbox programming if automatic) Consumer market cars hardly ever use full potential of the mechanics powerwise, because they must fulfill also emission controls! Chip tuning is popular now, even among truckers and farmers!
noobie1
Bay Area
I own two cars 2015 Audi A6 and 2015 Lexus GS Sport. Love driving the A6 but hate the Bose audio system. Driving the Lexus is less fun but the Mark Levinson audio system sounds really good.
JJB70
Singapore
The relative importance of power and torque is largely determined by the application. There are applications where torque is a significant limiting factor, particularly those needing very high starting and low speed effort. A lot of marine engines are more limited by torque than by power.
Krunok
Zg, Cro
As there is a linear relationship between the two which depends on RPM and that power is actually doing the work I really think torque is being mentioned much too often without any reason at all. With internal combustion engines it's anyhow all about cylinder pressure and the generated power. Torque is quite insignificant thing in between mostly being mentioned by folks who don't understand it (and here I don't mean you).
Blumlein 88
Another unusual compared to modern power curve is like those of large American sedans from the 1930s. Think Buick, Packard, that sort of car. A large displacement straight 8 with a very long stroke. Peak torque was at low rpm vs modern engines. Low power output for the displacement.
With such an engine in the time before automatic transmissions, you can get the car up to speed, and once in high gear just leave it there. It would pull down to 3 or 4 mph and smoothly, slowly accelerate back up to speed without getting out of high gear. Much reduced the amount of shifting.
I've not looked at any motorcycle mags in years. I know at one time they would include a test of top gear acceleration time for 50-70 mph or maybe it was 50-80 mph. Basically trying to make V-twins look good in a passing scenario. The large slow turning engines did fairly well in such a test vs sport bikes. Of course any sport bike owner wanting to pass someone would drop 3 gears and be long gone in the real world because they have so much more power. The torque of the V-twin doesn't get it done without power.
Someone mentioned peaky 2 stroke racing bikes. Yeah those are horrible in my opinion for use on public roads, but quite the ride if you have a chance to air one out on a track.
Krunok
Zg, Cro
One more thing: let's not forget that there is a gearbox between the engine and the wheels. Gearbox acts as a power transfer box where torque gets traded for speed - for that reason some call it a "torque converter", which basically it is. That means that pretty much all the engine power (minus various losses) is transferred to the wheels to do some work while torque is progressively reduced to enable advance in speed. So engine torque is really not something that needs to be discussed, especially not in the countries where power is specified not at the crank but at the wheels, as crank torque and wheel power really have very little in common. ;)
RayDunzl
Central Scrutinizer
Riverview FL
My new car is under-square:
Bore 87 mm
Stroke 103 mm
LumbermanSVO
They aren't that much different than cars with a big turbo for top end power and low compression. Super boring down low, but when the power builds, hang on! My old laggy turbo car wasn't a good daily driver, it wasn't the fastest thing out there either, but when the boost started building it FELT fast, and was a super fun weekend car.
JJB70
Singapore
Torque comes into its own with direct drive arrangements (i.e., no gear box) and with high starting loads (such as marine engines). As well as starting, torque is a serious limiting factor for acceleration in such arrangements.
W
W2S
The 335D X Drive does everything I need in a car plus with new penalties for Speeding in the UK
largest fine I think is £96k as now based on your earnings
All the spec's you need
Below we present more detailed data of the factory claimed performance and the ProfessCars™ estimation, including all detailed acceleration times, with comprehensive graphic illustration, top speed, accelerations on gears, speed vs rpm and overtaking times.
https://www.automobile-catalog.com/performance/2016/2162405/bmw_335d_xdrive.html
Or Just book a test drive at your Local BMW dealer and judge for yourself
Frank Dernie
Oxfordshire
Too heavy for that small a car (IMHO of course)
Thomas savage
The Watchman
uk, taunton
@Frank Dernie thinking about one of these Frank what do you think?
It's the 3.5 supercharged version so bit heavier than the old 1.8 version.
Ron Texas
How about some Detroit iron? I have the hots for one of these. 2020 mid-engine Corvette, probably 500 hp to start.
Blumlein 88
I'm sure that is going to be a terrific car. But I fear it may not turn out well for the Corvette as a product. The front engine version had an ample hatchback area. That allowed it to be a quite good do everything car for someone who owns only one car. You could buy groceries or other things in town, or pack plenty for trips, or even take your German Shepherd to the vet. etc etc as long as you could live with two seats.
The mid engine version is going to have pretty limited luggage or package space. I think the price will have to go up some. So higher price, likely higher maintenance costs for mid engine cars too, and no practical space may all bleed some sells off the car. I fear it may be a fine car, but fail to generate a volume of sales to make it worthwhile for Chevrolet to continue with it. I hope it isn't so successful a design it kills the Corvette.
I also prefer the long nose short tail look of a car to the mid-engine shape. But if the experience driving it is up to snuff I'd quickly forget about that. Maybe they know what they are doing and moving it up-market is a smart move.
Ron Texas
@Blumlein 88 Limited luggage capacity is a concern for me. It has to hold enough for two to hit the road with clothes and photo gear. It's said the base price is only going up $5k, but that does sound optimistic. Small differences in lap times between GS and Z06 models (200 hp more) prove the platform has reached its limits. Actually, my Camaro with its Stingray motor but 350 lbs more mass is stupid fast.
Frank Dernie
Oxfordshire
It is actually easier (though not often enough done) to get a good weight distribution for a fast road car with a front engine than with mid.
I suspect this car is to homologate this layout for racing in the very competitive production car series. Will winning its class at Le Mans etc add to sales? I doubt it so, as you write, this may be much less suited to current owners than the existing one.
The only Corvette I have driven was a ZR1 and I loved it, though the interior was a bit low-rent and rattly for the price (here in the UK)
