- Thread Starter
- #81
Weather here in Norway is finally approaching something somewhat closer to spring (or at least less like winter), so I've now been able to do outside measurements and some adjustments based on these, so I can finally present som useable full range measurements without noise from the room.
These may still be subject to change, but starting to look pretty decent. If we ignore the dip at 1khz (which is 3dB), this is essentially +/-2dB in the intended frequency range.
(The dip just below 300hz at the 30-45deg measurements is probably reflections from the ground, not actual frequency response)
Finally, some asked about using the SBS.1 as a center speakers, so did a quick 0-15-15-15 measurements. What I did here was put the speaker on the side, and then measured On-axis, 15deg to the left, 15deg to the right, and 15deg above (simulating a placement below a screen). Pretty consistent response, so I see no issue with using this on its side as a center speaker. Response below.
