Small 2-way speakers with linear on-axis and power response characteristics (Scan Speak and SB Acoustics drivers). H&V off-axis measurements included
Bicep
Such a nice design! I'm also from northern Europe and hope to get into DIY speakers. Do you have any advice about retailers for parts? Most chatter I see online order from partsexpress in the US. :/
D!sco
Congratulations on the review. Your hard work certainly paid off.
dcibel
Well done! It's surprising how well of a PIR you've got with just a basic sharp cornered rectangular baffle.
Maiky76
French, living in China
@XMechanik, as I said in the EQ post that's a great effort with only off-the-shelf components and simple woodwork,
I noticed that in your simulation the LF is not drooping as much as in the NFS data. Not sure why.
Maybe near field measurement inaccuracy?
The simulation of the 8L + tuning to 45Hz seems to match the NFS data characteristic
If I may, after doing a bit of simulation for the box tuning I would suggest tuning the cabinet to 51 - 53Hz instead.
That would result in a flatter response (up to +2dB above 50Hz) and most probably remove the need for EQ IMO (outside of room integration obviously).
The LF will be attenuated slightly but the power handling higher above 50Hz (about +3dB) so more usable in the useful bandwidth of the speaker.
All in all for a smaller speaker it might be a better compromise especially if listened louder.
Inertiaman
Any chance you've computed the port dimensions for such tuning?
D!sco
It’s an off the shelf port so you just bandsaw a few mm off and call it good usually.
J49
CO
Incredible. Nice work @XMechanik and thank you again for sharing this design.
My build came in around $300-350 usd for drivers and x-over components. Outstanding performance per $.
D!sco
It's an adjustable telescopic one, so both easier and reversible if you don't like the result.
Also means you could adjust it for each room. Neat. Way better than a precision port, even.
Ulf
This really makes me want to get into DIY! @XMechanik, I realise I am asking for free stuff here, but if you made a youtube video showing off the speaker you would get a lot of views :)
Maiky76
The surface of the port is too small relative to the active surface of the driver (about 11%).
Even at moderate SPL the air velocity in the port exceeds 5% of the speed of sound (343m/s) which is one of the criteria to dimension a port.
The port will be non linear very quickly (as the SPL increases) and restrict the output of the system at LF.
I am not sure what level is used for the NFS but it might already be the case during Amirm'smeasurements.
If you look at the review you'll see that the resonance just above 1k that matches the expected peak at 1100Hz and is only about 10dB down compared to the main output.
Could be better... but I understand the convenience of the solution adopted by @XMechanik
For the following sims I have included 0.77R in series with the driver because of the Xover I was lazy to do the Xover sim and check the actual value....
The sizes
45Hz -> 150mm instead of 145mm (my calculation are 3.5% different from the actual recommended port length not significant IMO)
52Hz -> 106mm, first resonance predicted at 1600Hz
The point is: DIY!
So I would recommend a port that provides better linearity (larger diameter) tuned to 51 - 53Hz instead.
Gringoaudio1
Calgary Alberta Canada
The sizes
The point is: DIY!
I have seen the standard box and port calculators online where you enter the T/S parameters but none that create port sizes given an input tuning frequency. Can you point me in the right direction please? Thanks.
Chris*42
Böblingen, Germany
The sizes
The point is: DIY!
...or use a PR and there will be no port resonance, SBAcoustics for example offers PRs with twice the Sd of the woofer - but this increases the price...
Hifihedgehog
Assembling and electronic work I am well acquainted with. However, I am new to from-scratch speaker builds. I do not have the facility or accommodations to do woodworking currently. Where would be the best place to get the panels cut?
mga2009
Thanks @XMechanik very nice design!!
If using in a small HT with 3+ SW, would you recommend a sealed alignment?? Any changes on the volume or XO?
Cheers!
