Small form factor CD player
Roy_L
Haifa, IL
Hello, can anyone recommend a quality CD player with a small "shoebox" footprint (like Cyrus, Bel-Canto etc.)?
Preferably with XLR outputs (which Cyrus's models lack, while costing an arm and a leg).
Thanks!
Timmeon
New York
R
Roy_L
Haifa, IL
Thank you all! But does anyone know of anything, well... fancier? Not audiophile-ridiculous, but something that would seem more at home in a hi-fi system?
raindance
Personally, I'd just get the Cayin, their stuff is usually decent.
Timmeon
New York
Pro-Ject CD Box DS3 is the best looking in my opinion. You get a choice of colors, and even wood side paneling. Black with walnut looks slick.
Timmeon
New York
There's also the Rega Apollo
Not my taste, personally.
JSmith
Algol Perseus
JSmith
raindance
JSmith
But it's full size!
mhardy6647
The small footprint + balanced output is pretty restrictive.
Noting that the OP used the word "preferably" vis-a-vis XLRs and given my penchant for wryness...
No XLR, but certainly petite.
:cool:
Chrispy
PNW
Just curious, but why play cds at all instead of simply ripping them and having more playback choices?
R
Roy_L
Haifa, IL
Because when I play a CD I can sit on the couch like in old times and just listen. I find that difficult when streaming music using the laptop (I don't have a dedicated streaming device).
Chrispy
PNW
I'm sitting on the couch playing albums...just like the old days, just no disc. It's not difficult, but rather easier in several ways without any loss of fidelity.
threni
/dev/null
You could replace your CD player with a raspberry pi running moOde, usb hard drive and a DAC. All your CDs live on the hard drive, and you listen to them all at CD quality, controlled from your couch via your phone/laptop/tablet etc. No more getting up to fiddle with bits of plastic between albums/tracks!
