- Joined
- Oct 25, 2019
- Messages
- 11,115
- Likes
- 14,782
So I did exhaustive research (and exhausting for me anyway lol).
If one is to take DCA’s recommendation seriously, ie 500 mE at 16 ohms and output impedance of less than 1, then the portable options are limited and expensive.
Chord Mojo or Mojo 2
IFI IDSD Micro Black Label or Signature
That’s either over $700 for something new or still having to spend over $300 for a used unit several years old… hardly a tantalizing prospect either way after having spent so much on the headphones themselves.
The cheapest option is to use the Apple dongles combined with Topping NX7 ($179) portable amp.
The others that come close to but do not quite meet the specs but might be worth trying:
EarMen TR-Amp
Topping NX4DSD
Monolith by Monoprice 24460
If I were you I would take a punt on getting an e1DA 9038S (G3) unless you use hefty EQ with your Aeons. Assuming you have a balanced cable that is.
Will it give ear bruising volumes? No- but it might just be enough and as portable as they come
9038S DAC - Shop Cheap 9038S DAC from China 9038S DAC Suppliers at E1DA Audio Store on Aliexpress.com
Shopping for Cheap 9038S DAC at E1DA Audio Store and more from on Aliexpress.com ,the Leading Trading Marketplace from China
www.aliexpress.com
