So my Focal Aria 948 is dead
HellcatJB
My Chora 826 just completely stopped working. The terminals gave an OL reading but the bottom woofer I removed shows 8ohms. I can't see anything visually wrong with the crossover. I'm tempted to turn my volume way down and bypass the crossover. Each driver has its own leads from the crossover so I wouldn't think the problem is down the line. I have always wanted to upgrade a crossover. But hell as far as I know it could be anything. I tried multiple channels and cables and it's definitely the speaker
Penelinfi
Things to check : were you blasting it with loud volume - protection device or cap may have died
Wires to speaker drivers
Solder joints
But if the speaker completely stopped on all drivers, check the solder points, leads for the terminal cup to crossover . If you are careful, touch the speaker leads directly to input on crossover PCB.
Cheap amp with protection is ideal if you have an expensive amp that will pop if you do bad things with it
HellcatJB
Solder joints
You were right. The leads from the terminals to the crossover board are thick flat bars. When the 2 pieces were attached, the flat edges and natural tension held them together so well that I thought they were still attached. Easy fix
HellcatJB
Solder joints
So I've received the soldering supplies and now I have to figure out how I'm going to tackle this. About 3/8" broke off of the "bar" for lack of a better word and I can only see a few options. 1) straighten the broken one and hope it'll reach. 2) replace 1 or both with heavy gauge speaker wire or 3) find a way to remake the "bars" out of copper. Focal has the complete crossover for $90, I'm already approaching that figure. Too late now, in for a penny.
