I recently switched to Manjaro after I got sick of windows. The only thing I havent properly figured out is the audio stack. I'm pretty sure Manjaro uses pulseaudio by default. I'm currently using Pulse Effects to eq and it's often clipping and some apps just bypass the eq (i dont mind this but they skip the pre amp too). Less importantly I havent been able to get the sample rate and bit depth to change from the default 44.1/16 I have edited the client.conf file but it doesn't change anything even after a reboot.
Thank you
Thank you
