Solid Dac Amp for Focal Elex?
Bafri
For my PC Desktop usage im using a Dac Amp for my Focal Elex. I dosent need that much Power, but wanna good all in one solution without beeing too expensive. Any ideas? Thank you
Jimbob54
The JDS El thingy all in one . Cant remember its name. I was going to say the Topping DX3 Pro but it has high output impedance.
OR- have a look at the E1DA 9038D dongle- would be great for them and could then use from PC or phone. (9038S if you want balanced)
B
Bafri
Its pretty expensive in Germany. Around 400€. Do you think the JDS Labs Atom or E1DA 9038D do this job as well? Or would i benefit from the Element?
Jimbob54
The Atom doesnt have an all in one version otherwise would be ideal- nothing about the Element above Atom sonically- just better case.
B
Bafri
I could you a chinch to 3.5mm cable to use my mac mini M1 that has good internal sound as a Dac / Soundsignal source. Oue buying a seperat Dac. Would they sound significant better than the E1da? Im asking because i would get the E1da for around 85€ and the JDS Labs Atom for around 150€ to Germany.
Jimbob54
Why not just use the mac and have done, why do you need anything external?
B
Bafri
Because the Powerinput has too much distortion in comparison with Apple Dongle and my iPhone 12
B
Bafri
would i benefit more from the JDS labs Atom Amp than E1da?
Jimbob54
If you're happy with the apple dongle driving them, just get another for the mac then.
Helicopter
Michigan
I am happy with these combo devices:
Schiit Hel
Focusrite Scarlet 2i2
Loxjie A30
They all have something more than DAC/HPA though.
B
Bafri
The apple USB c dongle, reviewed very favourably on here. Unless you buy the EU /UK version with its ridiculous 1v limit.
do you have a ebay link or something like this? I living in germany so i have to import
Jimbob54
Urgh. Its a pain. They have different model numbers but can't remember which is which. But that said, I imagine the one with your phone is similarly limited so for the sake of a few E, try the EU one
Quebec
Hello ! I don't really know if I should revive the thread or create a new one, so I'm gonna take my chance here first. I read posts on reddit, made one, but I still have questions and have more confidence in the answers I hope to get here. Just got the focal elex (who would have guessed) and I am contemplating a few options.
  • the atom JDS lab that I can get under 100 CAD (used)
  • a Cambridge DacMagic plus for around 300CAD (used)
  • a drop THX 789 for around 250CAD
  • a combo amp/dac liquid spark for 200CAD
  • the SMSL SP200 for 180is CAD.
These are the options around me. My hidizs S9 pro does not have a 6.5mm output or XLR (I also tend to take it everywhere with me). EDIT: because formating is hard.
EDIT EDIT: Fiio K7 has been mentioned. 330CAD
Elitzur–Vaidman
Imo, you should start off with the apple dongle first. It's honestly plenty powerful for most headphones
Quebec
@Elitzur–Vaidman I have an android phone, a quick glance at the subject suggests it might be a problem (didn't see anything about linux compatibility). I would rather just get an adapter for the hidizs if it is sufficient.
Liberte
I use this for when I want to plug my Elex into a 3.5mm source, it puts less physical strain on my source's (Mojo) output than a non-wired adapter.
Elitzur–Vaidman
I have an android phone as well. The only issue is android limits the max volume to 0.5V instead of the full 1V. That'll still get the Elex plenty loud imo
