Some stupid Interconnect questions
SuperDerpBro
Canaduh
I would like to try my hand at making a couple very short RCAs. Less than a foot. I'd also like to make a short SPDIF cable for a CD player.
I have a bunch of these.. could I use a short one (0.5m) as coax for my CD player while I wait to make my own?
Is there a type of wire that is inexpensive and would work for both RCA and COAX? Could I just cut up some of the above?
Can the normal RCA plugs also be used for my DIY coax cable?
I think I know the answer to all of these. I'd just like to make sure, heh. :/
Cheers :)
Doodski
Cheers :)
If you want 6 inchers these are great and they use a bendable coax cable design which is very easy to work with for beginners.
If you want the experience of assembling a cable then use RG6 in black color or white. It is easily available and is tough and durable.
solderdude
The Neitherlands
Nice touch.... 'van den HUI' looks like it says 'van den Hul' :)
SuperDerpBro
SuperDerpBro
Canaduh
Yeah, I saw that...lol. ClassY!
I love it. LOL
wut? lol
SuperDerpBro
SuperDerpBro
Canaduh
If I use RG6 do I have to use compression connectors and tool? Or can I solder to RCA plugs?
solderdude
The Neitherlands
Yes, you have to solder RCA plugs.
SuperDerpBro
SuperDerpBro
Canaduh
Looked on YouTube and all I could find was people using RCA compression connectors on solid core. With a special tool, that I don't want to buy (heh). I'm okay with soldering. Just wanted to make sure. :)
What about RG-59 75 ohm?
I think I have one of these (6ft) that I can chop up.
solderdude
The Neitherlands
I would not use solid core coax wire but supple ones.
Solid core is not needed anyway nor desirable for short lengths.
SuperDerpBro
SuperDerpBro
Canaduh
SuperDerpBro
SuperDerpBro
Canaduh
I found a very long component cable in my closet. the only identifier on the cable is "OFC Premium Componant Video Cable"
Would this be ok for a 6 inch RCA?
SuperDerpBro
SuperDerpBro
Canaduh
Thanks. :)
The core seems quite thin. A bit thinner than a normal TV coax cable when I hold them together. But I will try it. :) heh
