Sonos Play 5 vs Genelec 8361A
johnwolf
Pardon me for the ignorance.
I know the two speakers are not at the same level.
However I have both of them on the same wall, playing the same music but I can't barely figure out their differences.
Two Sonos Play 5 + Arc, using Sonos App/AirPlay
Two Genelec 8361A, using computer and RME babyface Pro
They are both on the same living room wall. The living room is about 15x15 with high slanted ceiling.
Please educate me.
dfuller
The 8361A should go considerably louder and extend quite a bit deeper.
Mario Sanchez
Well, Sonos knows what they're doing when it comes to speakers, and for an average person's living room use (that is to say, at a moderate loudness which neither takes the spotlight of the whole space nor turns one's cochlea into a mush), the headroom difference probably isn't so obvious, and most music don't have *that* much bass content anyways. Have you tried using GLM on the 8361As?
Now, now, if you're interested in selling those Genelecs...
Peluvius
Please educate me.
What was it that motivated you to buy a pair of 8361s in the first place?
Soundstage
Please educate me.
Could you please send a picture? thanks
jae
Hmmmm....
jae
Would love to see your in-room measurements of both
Pearljam5000
Please educate me.
So the 8361 is garbage?
G|force
Pioneer , CA
I was under the impression that the main reason people buy Sonos is because they only need an AC power connection for each cabinet and users can shoot BT to them making the process of bringing them into their stylized lifestyle environment relatively simple.
Buy two or ten of them and 'fill the space with sound.' Sure. I don't remember anyone suggesting Sonos are world class sound packages.
If you are going to use Genelec Ones, that requires an AC power connection and a signal cable, preferably balanced analog or AES from a suitable source. Used optimally, Ones require ethernet cables run in series then homerun to the GLM box.
And Ones are nearfield, not 'room fillers.'
Apples and oranges IMO.
SuicideSquid
If you put a good speaker in a bad room it'll sound bad.
But also I don't think I really believe that the OP has a pair of 8361s or that they sound substantially similar to Sonos Play speakers, even in a poor room.
jae
Not necessarily. With these controlled directivity and ruler flat speakers like genelec etc., even if you put them in an bad room they will still perform well past a certain frequency.
DMill
If only the Sonos were that good. I wish it were true, but wishing is not gonna make it happen.
