PenguinMusic
- Joined
- Dec 20, 2019
- Messages
- 640
- Likes
- 386
Hi,As described in the Headphone EQ Help section, oratory's PDF must be converted to a .txt file, before you can import it into the tool:
Headphone EQ
Headphone EQ helps to detect and compensate for the unwanted resonances in high-end headphones and earphones.mathaudio.com
Attached below is the correctly converted .txt file.
As described in oratory's PDF, you can manually tune the gain of certain bands to preference:
Or leave them as-is for stock Harman.
I think Maiky76 also gave his own PEQ settings and I found them to be slightly better than those from Oratory.
Of course that is a matter of tastes
But it has to be stressed that those PEQ settings will reduce the amount of bass.
The Z1-R is indeed a bass heavy headphone...
So I am not sure n0thing will like those settings :-(
They will all reduce the amount of bass to give something more balanced...
So n0thing, you will have to adjust band 1 quite heavily I think...
Me, I find the Z1-R too heavy on the bass, and that is why I need those PEQ settings...
Regards.
