Sound card and headphone AMP with optical inputs
Blujackaal
Since I'm getting loud static from my PC, Would optical cable stop that noise totally?. I don't have a optical out on my motherboard but I'm trying find a £50 sound card with toslink ports and use a PCI-E extender to avoid my 1080ti. Is there any headphone amp with a toslink input?.
solderdude
The Neitherlands
You probably want a DAC with headphone amp that has an optical input.
An amp can never have a TOSLINK input.;)
One would expect an optical input to stop the noise, just like a real USB isolator would and perhaps a line-level audio transformer could when it originates from the PC power supply.
Trying to ground devices a bit better (not so easy sometimes) may be the first step to try without making any investments.
B
Blujackaal
Hard to test that without checking if it our house the cause or my PC. It only awkward because they didn't tell they used a common small motherboard that had no toslink or had a sound card too close my GPU that not toslink out. But i already found a sound card with toslink output and a 1x PCE-E so i can install it in very bottom area of my case.
Inc a DAC with toslink input.
