Speaker Decoupling with Small Rubber Pad?
hutt132
I currently have my Sierra 2-EX speakers on 4 small rubber pads, sitting on some Monoprice stands filled with gravel.
Would the small rubber pads be adequate enough for decoupling purposes, or should I try out something thicker or use foam?
Jbrunwa
Seattle
Your speakers look good on those stands! I have a pair of Revel M106 speakers on the same stands using the rubber pads supplied with the stand, stands filled with non clumping kitty litter and a handful of blue-tak beads holding the speakers firmly to the stands in addition to the rubber pads. I didn’t see any anomalies in the response with either Dirac or REW. I previously tried sorbothane sheet and didn’t hear or measure any difference.
alex-z
I have tried speakers on stands, sitting on subwoofers, rubber sheets, foam wedges, and various combinations.
They all sounded the same, and measured within margin of error. Well built speaker cabinets aren't transmitting enough energy to need decoupling, and the same goes for subwoofers.
By far the most important thing is your speakers sit at ear level. Most bookshelf speakers have only 10-15 degrees of vertical listening window.
Loathecliff
Iberia & UK
In my experience having an inert floor matters far more.
