Speaker into a tube - what happens
David James
I went for a hearing test and the audiology clinic used a kind of “in ear monitor” with, from what I could tell, transducers coupled to a tube, similar to silicon tubing, and then to foam plugs on the other end. I’ve attached an image of something that looks like it could be the same. I always thought a long tube was a bad thing but the sound of the technician’s voice was uncannily clear.
This has made me curious about what happens when a transducer is coupled directly to a tube like this. My experience at the clinic suggests that the transmission is linear but I don’t know any of the science. The complexity of transmission line enclosures made me assume things for very complicated in such a situation.
Blumlein 88
I've not seen anything like that. However, I notice the name Etymotic on them. So those guys make some very good IEMs. I have a pair and they are darned clear, but I hate how deep they have to go. They did originally do business for what I suppose would be called audiometric gear.
fpitas
Northern Virginia, USA
A tube is only bad if it's not properly terminated at one end to eliminate pipe resonances.
D
David James
In this case they terminate in my ear canal.
Could you elaborate on what “properly terminated” means?
NTK
US East
D
David James
i think I was unclear about what I want to know.
What happens to the sound if the transducer is coupled tightly to a long tube, as it is in device in the picture?
fpitas
In this case it must be terminated at the sending end in its characteristic acoustic impedance.
D
David James
