Speaker measurements vs. actual perceived audio characteristics
Kain
Sorry if this is a newbie question, but say that two different speakers from two different brands have the same measurements. How come they still end up sounding different? If measurements don't fully indicate the audio characteristics, why place so much weight on them? Or maybe they do sound the same? I'm not sure. But I do know that two different subwoofers with identical measurements definitely don't sound the same.
K
Kain
Didn't know that. So are you saying that if the measurements were identical, they would actually sound the same? How come that doesn't work for subwoofers?
FrantzM
It does work for subwoofers. Same measurements, same position in room? Same results...
K
Kain
If a ported and sealed subwoofer have the same measurements (along with position in room and everything else), they will sound the same? I thought ported subwoofers offered more tactile response compared to sealed subwoofers.
How does a subwoofer sounding "thick" or "bloaty" vs. "clean" or "precise" show up on measurements?
FrantzM
THD, IMD, FR, level, etc ... you know ... measurements.
pozz
Слава Україні
Editor
In almost all cases this is do with room effects and not the subwoofer. Subwoofers are remarkably similar apart from output capability vs. frequency (according to CEA 2010) and footprint (i.e., size), as well as features. I like DSP in mine, for example.
The other thing to say is: no speaker measures the same as another. There is always some level of difference.
Frgirard
Could you define the same measurements?
Mosquito
It never happened that two loudspeakers of different brands measured the same.
Frgirard
Not sure two same model of passive speakers have the same measurements.
K
Kain
Okay, there seems to be a slight confusion regarding what I meant. When I stated "measurements", I really meant frequency response graphs such as the following:
Katji
Listening spaces acoustics vary and heads [neurology, psychology --> perception] vary.
Katji
Can you define the meaning/s of those adjectives, so that all persons will understand them the same? ...You might need to define them in terms of [ranges of] test measurement results.
Frgirard
The distortion is a great part of the sound speakers.
As inter modulation distortion IMD
The step response.
preload
California
Which two speaker models did you think have identical cea2034 measurements?
K
Kain
It's a hypothetical question. But I've seen JBL and Genelec speakers with similar "flatness" in CEA2034 measurements but with comments stating that Genelecs are considered bright.
preload
California
The ability of the internet experts to "interpret" a complete CEA2034 suite of measurements is greatly exaggerated.
