Speaker protection
Nicholas B
Adelaide, Australia
Hi All!
I haven't seen any discussion on speaker protection boards or similar. Perhaps I haven't looked hard enough :D.
In any case, I'm running a pair of Musical Fidelity X-A200 monoblocs (for which I recently replaced the e-caps and adjusted/corrected bias).
These still work well, but are getting long in the tooth. I don't believe there are any sophisticated protection circuits inside - unless you count fuses. I'd like to get some protection for my speakers in the event of catastrophic failure of the amp(s).
Would something like this from AIYIMA be suitable? Are there better options you think I should be exploring? Presumably these units would have little effect on the sound.
Thanks for any input!
Cheers,
Nicholas
NTK
US East
Hi All!
Cheers,
Nicholas
This is from the Hypex NC500 OEM datasheet.
egellings
DC in speaker is not a problem for me; it won't make it through the output transformer.
somebodyelse
MakeMineVinyl
Santa Fe, NM
Recent amplifiers use fast acting DC protection which cuts current drive in the case of excessive DC and / or current on the output. Relays which were used in older amplifiers are absolutely not reliable because the contacts can fuse closed during the specific type of event they are supposed to protect against. A long time ago I lost a woofer because of this (fortunately is wasn't in my main system).
To address the original question, I'd say that fuses are an option.
Nicholas B
Nicholas B
Adelaide, Australia
Thanks for all your responses!
I've been reading up on speaker protection via Doug Self's amplifier book. Looks like fuses create distortion and aren't particularly reliable. So maybe avoid these, even though they would be particularly cheap and easy solution.
As mentioned, looks like relays may be a mixed bag, with potential for problems. So not ideal either, especially with a powerful amplifier.
I may investigate the Guardian 86 from Neurochrome as a likely candidate.
egellings
A fuse can work well if it is included in the amplifier's feedback loop with adequate loop control should it open. Having the fuse in the loop eliminates the effects of its series resistance, which may be nonlinear w.r.t. conducted current.
DonH56
Monument, CO
I have no idea the output topology of your amplifier, but one thing to watch is that some (perhaps many) aftermarket output protection circuits using relays or switches ground the (-) amplifier output. This is a big problem if it is floating, as in a bridged design, or for certain tube amplifier outputs (e.g. older ARC amps grounded the 4-ohm tap, not sure what others do).
Personally, I would start with an inline fuse of fairly high current rating to help in the event of catastrophic failure, and drop a note or call Musical Fidelity to ask exactly what sort of protection the amplifier already has. Hopefully it's a non-issue... A lot of older amps had some basic output protection built in (Blaze Phase Linear being a notable exception). A fuse will indeed add distortion, but probably much less than the speakers themselves until it is near its breaking point.
Nicholas B
Nicholas B
Adelaide, Australia
Thanks Don.
The amps are unbalanced and solid state, and I believe should be fine with Guardian 86 system (link in my last post), which uses mosfets for switching rather than relays. I ordered them right after my last post and will report back here, though that could be a few weeks.
I don't see any form of protection for these amps should the output devices fail, in which case repairing them will be above my pay grade. I do however want to protect my speakers (Duntech Black Knight - a John Dunlavy design). These are 70kg, three way five driver design, over 6 feet tall, 90 dB @ 2.83V, 2.8 to 10 Ohms impedance, but with no sharp phase angles. My amps are a bit over kill for these as measuring with a 'scope, even when I go nuts, I rarely feed them more than 100W on peaks.
If my amps one day die, maybe John Yang will have out a new higher powered version of the just released PA5 :p.
Just some basic info on the MFs:
There's also a manual, here. Though it doesn't show schematics. I did however find a hand-drawn version on another forum, which looked spot-on, so that helped. Service manuals appear to be unavailable AFAIK. Though if anyone knows of one, I'd be all ears!
Probably more common in the UK than the US, though I'm in Australia.
tcpip
The Guardian 86 is a great choice, I think. The latest version of the Guardian86 has disconnected the speaker return line from the system ground, therefore it can be used for bridged amps too.
There's another option, more DIY: https://www.diyaudio.com/community/...sr-dc-speaker-protection-and-delay-gb.340694/
This is quite popular, and its performance has been measured and it adds no perceptible or measurable distortion, I believe.
Nicholas B
Nicholas B
Adelaide, Australia
I've been using the Guardian 86 devices for a couple of weeks now (the first version) and they work flawlessly. Well, I haven't actually tried putting a significant amount of DC on the output of my amps, but I don't notice that they're there while playing music. I turn on the amps and the Guardians simultaneously via one wall switch. This seems to work well.
