hello,
I have a living room, 5mx8mx2.5m, where I have limited options to position speakers in. They need to be near the width wall, and the sofa is near the opposite width wall.
| - ......................... x |
x is the speaker position, and the crude ascii is the sofa, the holes on the bottom wall are the doors. The top wall on the drawing looks outside (four windows)
There is about 6m distance to be covered.
This is a living room, so there is a big compas table across the room, with eames wire chairs, near the speakers.
I have a dual ncore nc400 amp with a dac source (pi+allo).
What kind of characteristics should I look into my future set of speakers to cover this space?
I only listen to music, but adding an active subwoofer is possible.
Budget around 1500 euros.
Thanks!
Luc
Thanks!
Luc
