Speakers on desk - reflections
Yorkshire Mouth
God's County - Yorkshire
My new set up is planned to have a pair of studio monitors on top of a pair of IsoAcoustics ISO200 stands on a desk - probably at a fairly low extension.
Due to where/how there'll be positioned, there will still be 10cm-20cm of naked desk in front of the speakers, and I wonder if there's a chance of reflections from that area of desk.
And, if there is, what can be done? Some sort of foam, or soft material?
Many thanks.
holdingpants01
you could angle them upwards, this should minimise reflections, it's good to measure afterward, could be enough depending on directivity properties of the monitors
ozzy9832001
Many thanks.
Depends on the size of the desk. The desk will reflect sound that is smaller than it. Otherwise, diffraction occurs.
LTig
Europe
Yes, this will happen.
Put the speakers higher (tweeter at ear height). It worked great with my Genelec 8020a.
Yorkshire Mouth
Yorkshire Mouth
Cheers. Again, I already plan to do this, on a pair of IsoAcoustics ISO200 stands.
I’m sure that will negate some (probably most) of the issue, but I’m just wondering if a small issue remains, and what -if anything - can be done.
Or, having put the speakers in stands, and tilted upwards, should I not be worrying at all.
The monitors are JBL 308P Mk.2. By my calculations, they’ll need to be on the minimum extension, and a modest tilt.
LTig
Europe
If you put the tweeter at ear height there is no need for an upwards tilt. I have no audible problems with this setup on my desktop.
Yorkshire Mouth
Yorkshire Mouth
The kit isn’t here yet. The IsoAcoustics don’t have infinite adjustments for height and tilt, and as far as I can tell, the ‘legs’ would put the tweeters just below or just above ear level. I’ll know more when they’re here.
Berwhale
This chap doesn't seem to worried about it!
Although the article says...
...and that the desk surface is significantly lower than the monitors, so as to avoid strong reflections bouncing off the desk and into your face. If in doubt, put a mirror flat on your desk between you and the speakers, and if you can see the speaker, particularly the tweeter, when you look in the mirror, you have a potential reflection problem which should be addressed by moving the speakers if possible. Where the speakers must stand on a desk or shelf, foam isolation pads help keep the sound clean, and some products also provide a means to angle the speakers up or down if necessary.
LTig
Europe
You can always put a book underneath the stand or speaker.
