SPL Volume8 Review
Rate this product:
    Votes: 31 22.1%
    Votes: 79 56.4%
  • 3. Fine (happy panther
    Votes: 27 19.3%
    Votes: 3 2.1%
This is a review and detailed measurements of the SPL Volume8 8-channel, balance volume control. It was kindly sent to me by a member and costs US $799.
SPL nails the look and feel of this active unit. It is a substantial box but not too big. 8-gang volume control is custom made and muting is performed using a relay. Input/output is provided through DB-25 connectors so you need to buy those "pigtail" cables to go to and from XLR (or RCA):
SPL Volume8 Measurements
I set the unit to max volume and tested channels 1 and 2:
Distortion is quite low at -120 dB but I was disappointed to see power supply noise and harmonics bleeding into the unit. That sets the SINAD, i.e. dwarfs distortion as we can see in SNR measurements:
Frequency response is flat and extended which is nice:
SPL Volume8 Measurements Frequency Response 8 channel balanced volume control DAW.png
Not so nice is modest channel separation:
SPL Volume8 Measurements crosstalk 8 channel balanced volume control DAW.png
Distortion rises with frequency:
SPL Volume8 Measurements THD vs Frequency crosstalk 8 channel balanced volume control DAW.png
The higher noise floor shows up as a constant as we sweep the input level:
SPL Volume8 Measurements THD vs Level  vs Topping Pre90 8 channel balanced volume control DAW.png
I was surprised to see channel match lost even at higher volumes:
SPL Volume8 Measurements Channel Balance 8 channel balanced volume control DAW.png
As usual, your sample may vary.
As I noted in the introduction, I really like the look and feel of the Volume8. Ability to handle 8 channels is also handy in multichannel setups. At this price though, I expect to see perfection and we miss that in a number of places. I worry about noise degradation through the unit and loss of channel balance.
Swayed by the nice large volume control :), I am going to recommend SPL Volume8.
5th element
By the looks of things this isn't a fully balanced design. It takes the differential inputs, converts them to single ended, does the volume control stuff, then sends the signal back through a single ended to differential line driver. What a disaster. No wonder the channel separation is terrible. If it was fully balanced inside this would be far better.
They'd get better performance using two CS3318 volume control chips. Buffer the inputs, feed the CS3318s, buffer the outputs. Fully differential input to output. Then you'd get perfect channel matching, no degradation over time and no requirement for an 8 gang pot. You can control the volume using a cheap single channel pot and simple micro controller. Multichannel balanced volume controls are not meant to be done via potentiometers.
Rja4000
Liège, Belgium
Very similar results than its small brother Volume2 (2 channels, half the price) that I measured here, back in 2019.
This design becomes dated, I think (we see "2005" on the board of the Volume2).
But that's a nice looking device, without real fault (except the mains leakage, but I can't hear it) and pleasant to use due to this big smooth knob.
wisechoice
Thanks for this review, Amir! Looking forward to trying this (used) unit in my 4-DAC balanced setup for 5.1.2 home theatre and surround listening.
For those who are interested, @pos measured the balance of all 8 channels across the volume range many years ago. He posted the results here:
Tl;dr is that channel balance appears to be best at 50% volume and higher.
Ralf Stocker
Some companies can't even make a decent potentiometer. This $10 device will then charge $800.
Billy Budapest
I expected much better performance from an engineering-focused company like spL.
Geert
SPL has the looks and the price, but somehow never manages to convince me. Decades ago a colleague of mine had their expensive channel strips..., naaah...
Rja4000
Liège, Belgium
Gee, going off the SPL website you’d think these guys are at the cutting edge of engineering.
im becoming increasingly sceptical of all manufacturers claims
Well,
Their main target is the Pro market, which is quite conservative.
The products like the Volume2 or Volume8 are using old designs and components one could find in consoles in the early 80's.
They do the job.
Their products may not be at the cutting edge of performance, but they developed some interesting and innovative devices, like the Transient Designer, that were great value for Pro.
OK, that was quite some time ago.
Now the Pro market is pretty much about software... or legends.
So you can understand they are more building on this legend... look at diversifying target with more "Audiophile" products (they try to monetize the legend), and don't invest a lot of money on R&D. (But I may be wrong)
mdsimon2
Detroit, MI
Unfortunately it is pretty much dead on the SPL specs. They quote A weighted noise at -102 dBu (presumably 20-20 kHz), knocking this down 3 dB to roughly get unweighted gives you -99 dBu. In terms of residual noise this is 10^(-99/20)*0.775 = 8.7 uV. Calculating SNR at 2.4 V gives us 20 x log (2.4 x10^6/8.7) = ~109 dB so very close to the ASR measurement. Even if you don't knock it down 3 dB for A weighting you are still looking at no better than 111 dB SNR at 2.4 V.
Michael
Rja4000
Liège, Belgium
Michael
Which is, most probably, enough for the task.
mdsimon2
Detroit, MI
I guess? I bet a lot of people use this device to avoid digital volume control but it isn't hard to beat this level of noise with a DAC like the MOTU Ultralite Mk5 so you are actually hurting performance by using this. Now you do get a nice big knob and I personally find mains related noise less audible than wide band noise so in practice I bet it is fine, just seems like a lot of money for how it performs.
Michael
ExUnoPlura
Oregon Coast
As a total aside, I’m quite suprised this works in English. Most interesting. Learn something every day.
"Gang together" switches/controls is common English parlance. Etymology likely from gang as a group of people working together. Here's from Oxford's LD:
Old English, from Old Norse gangr, ganga ‘gait, course, going’, of Germanic origin; related to Scottish gang ‘go’. The original meaning was ‘going, a journey’, later in Middle English ‘a way’, also ‘set of things or people which go together’.
Not surprising that it would work in German, Dutch, etc. in a similar way. Sorry, linguist in me couldn't resist tracking it down!
Rednaxela
NL
Thanks @ExUnoPlura, much appreciated!
Thing is gang must be one of the best known English false friends to Dutch speakers.
From your explanation I understand they have more in common than I always thought.
sarumbear
sarumbear
Their specs and what is measured here are exactly the same. Why the “gee” and skepticism?
