"Stand Subwoofers" like the Genelec W371, Kii BXT, etc. Ideally with DSP & Multi-Drivers
Martin
Cape Coral, FL
LInkwitz was trying to design around the idea of having the sub as a stand
I think somewhere there was a measurement about vibration send up from sub to the main.
I have always liked the sound of the big Linkwitz speakers... You cannot beat a properly multiamped systems using DSP and active crossovers.
Martin
Martin
Cape Coral, FL
with $35,000 I'm dubious about the Porsche or a wrecked Porsche...
$35K is the going rate for a good, low mileage 12 year old Porsche 911. Just got to know what you're getting into.
Martin
nm4711
I can‘t remember if I have seen measurements about this, but I have seen this video:
Of course I don‘t know if they are placed on solid ground or on carpet, etc.
fredoamigo
South East France
Martin
not in europe my friend ! here the price of second hand 911's is soaring ;)
Thomas_A
Sweden
DIY sub stands are cheap:
hege
Finland
Nothing that some Sorbothane can't fix, assuming the subs hold steady on the floor. After putting few correctly specced bits between my Gennies and 18" BMS, there's absolutely zero vibrations coming though.. and the top of them does vibrately quite a bit when cranking. :)
AudioJester
The guy who put up that video posted on the LX/oplug forums that the issue was uneven floor surface. But, yes the premise of the bridge design by LX for the mids/tweeters was to avoid vibrations from the bass drivers/cabinet.
Bear123
ZOMG MY SUBWOOFER TWIN! I think those BMS are amongst the top 2-3 best 18" drivers made! I have the pair that Josch Ricci at Data-Bass tested.
Rick Sykora
Stow, Ohio USA
Here is my bass module for my RS621 monitors. At the time, I thought the idea was pretty original!
Rick Sykora
Stow, Ohio USA
I think Rogers produced their AB1 subwoofer stand for the LS3/5a over 30 years ago and the "Puppy" subwoofer for the Wilson Audio WATT to sit on came out in 1990 iirc.
Interesting as I did research at the time (and it was not 30 years ago) and did not find much. Although I have owned some British speakers over time, did not come across Rogers in US. Am not nearly in the same market as Wilson Audio, so pretty sure it was not them. I recall the design was very modular and seemed well made. The design had some damping feature between the bass module and the monitor.
Internet search capability is much more advanced now and I have not been able to find my previous result. In response to the OP, my recent searches come across RBH frequently. RBH has an offering but is $10K per pair. While I get market-based pricing, I cannot rationalize them as a reasonable value :oops:.
JohnBooty
Philadelphia area
Even if it wasn't DSP controlled, a multi-driver stand could perhaps be calibrated with a MiniDSP and get rid of room nodes by emitting bass from a few spots for a more universal application that wouldn't rely in proprietary stuff and having all the speakers from the same brand.
This is a fine idea. I've been running my system this way for a few years and I'm very happy with it -- a pair of SVS SB-1000s as "subwoofer stands" for a rotating cast of bookshelf speakers. Due to awkward room layout this was kind of my only option but it's been very enjoyable.
One way to make this easier is to use a receiver/amplifier with a pre-out/main-in loop like the Yamaha A-S700 or the discontinued HK 3490. Using this you can wire up the MiniDSP for crossover duty inline with the receiver, and then continue to use all of the receiver's other niceties like input switching and volume control.
As for other examples, I know Selah Audio sells systems with this arrangement. http://noaudiophile.com/Selah_Mejor/
However you should refrain from this idea. The best position in a given room for a sub is very seldom identical to the best position for the sats, so either bass suffers or soundstage.
This is more true for "a sub", as in "a single subwoofer" than it is for multiple subwoofers.
With multiple subwoofers room modes are greatly mitigated, giving you placement flexibility.
Additionally, subwoofer output is typically a lot more localizable than people realize. Utilizing a 80hz crossover and 12dB/octave slope, you're still getting audible output (-10dB) up at 160hz which is localizable. One more reason to reduce the distance between speaker/sub when feasible. (Of course, a lower crossover point and/or steeper crossover slopes help with this as well)
It's true that "dual subwoofer stands" positioning may not give the max possible SPL compared to other positions. However, in my experience, a pair of subwoofers will have plenty of headroom to spare in most situations... a pair of decent $500 subwoofers is going to have no problems keeping up with pretty much any bookshelves in existence.
stevenswall
stevenswall
Orem, UT
Would you consider the Genelec w371 to more like "multiple subwoofers" spaced a few feet apart? I think that's part of why I think it would work. If the stands each have two drivers, spaced as far apart as possible like on the W371, then a pair of those "towers" would be like having 4 subs.
Concerning crossovers, is there an advantage of a 12dB/octave slope? I choose 48 because it's the steepest, and would probably choose whatever the higher number is. I *think* this would also get rid of some lobing in 2 way monitors. Not sure what the drawback is or if there is one. (I don't believe it's time, because a DSP could time delay whatever was necessary.)
Bear123
Limiting sub placement to the same position as L/R is counterproductive and probably eliminates one of the main advantages of running dual subs.....improved sound quality due to a better frequency response resulting from *proper* positioning of the subs. Might as well just get towers that play lower.
JohnBooty
Philadelphia area
Folks in this thread dismissing "subwoofer stand" positioning, despite lots of well-regarded commercial examples and experiential evidence to the contrary. If this was such a flawed topology, why did we ever have tower speakers in the first place? By this logic, then every pair of tower speakers capable of putting out deep bass is fatally flawed.
I'm not familiar with those Genelecs. At first glance it seems like the dual drivers achieve some sort of dipole thing and I think the intent is that you wouldn't need more than one unit. I'm not sure if a second unit would be beneficial, detrimental, or merely superfluous.
As for crossover slopes, a steeper slope may cause audible discontinuity particularly off-axis as the subwoofer will have a different dispersion pattern than the speaker to which you're crossing it over. On the other hand a shallower crossover slope probably opens you up to some more phase/cancellation issues as in my "80hz @ 12dB/octave" example where the subwoofer's playing somewhat audible content all the way up at 160hz. Bit of a cop-out answer but ultimately it comes down to experimentation with one's room and equipment I guess.
The one thing I can say without reservation is that lower crossover points are always beneficial assuming the main speakers are capable enough.
Kvalsvoll
Norway
There are technical reasons for why the separate bass-system solution is superior to the old-school full-range speaker. I would not necessarily call it flawed, because it works - sort of, it is just that alternative solutions are so much better.
Here is the fr for a traditional speaker, and the fr for the new system that replaced it:
In the old system, the bass is made up of a couple of strong reasonances, very uneven response. No eq can fix the 60-80hz dip. Of course, all full-range speakers in a room are not like this, but something quite similar is common - uneven, colored, resonances. The new system is essentially flat.
When we look at what happens in time, it gets really interesting:
We see that it is not only the steady-state frequency response that was compromised, there was severe problems with group delay and timing as well. (This spectrogram plot shows frequency along horisontal axis and time upwards, sound level is visualized with color. We see what happens to the sound in time across the frequency range. Ideal is a thin, straight horizontal line at t=0.)
Fixing this with eq will be difficult, using just minimum phase eq will not work. Then the idea of acoustic treatment pops up, only to be dismissed when you realize anything that actually works will require rebuilding the room.
Fortunately, there is a realistic and very good solution. The bass-system here consist of 2 small subwoofers located where they could fit in, and according to advise given. Not necessary to try every possible location and measure. Since this bass-system has dsp with proper eq capabilty, it was easy to simply remove the only resonance that was left. The result is a system with smooth frequency response and good timing with no resonances across the whole bass range. Solved.
