- Thread Starter
- #21
Wow...That's all? That is very cool.
Very very nice. That sure beats the days of using a compass, level, home made angle of the dangle meter and compound angle ready rod and bolt adjustments.
You had to do that when there were only a few hundred sats or ?Very very nice. That sure beats the days of using a compass, level, home made angle of the dangle meter and compound angle ready rod and bolt adjustments.
Yes, I read that you determined a separate router was required. Real time is so nice and having the cel tel app in hand at the actual dish is so nice to have.It was real time when I was aligning it the first time. I'm going through a separate router now.
Yes, everything across the Clark Belt has to be aligned using compound angles and set screws/bolts to lock it all in place once aligned. They had to be aligned really tightly because the picture quality would be reduced on the satellites in the middle or at the ends and when it rained or snowed it was critical that maximum signal strength was calibrated into the alignment. It was really fussy stuff until we made the home made angle meter device and that simplified things greatly. We used a perfectly calibrated dish mount to make the angle meter and then applied that angle meter to the other dishes we where setting up and we could come very close to calibration before even turning on the electronics. Shortcuts like this made it much more bearable and less finicky.You had to do that when there were only a few hundred sats or ?
That was the Starlink stuff or predecessors, tho?Yes, everything across the Clark Belt has to be aligned using compound angles and set screws/bolts to lock it all in place once aligned. They had to be aligned really tightly because the picture quality would be reduced on the satellites in the middle or at the ends and when it rained or snowed it was critical that maximum signal strength was calibrated into the alignment. It was really fussy stuff until we made the home made angle meter device and that simplified things greatly. We used a perfectly calibrated dish mount to make the angle meter and then applied that angle meter to the other dished we where setting up and we could come very close to calibration before even turning on the electronics. Shortcuts like this made it much more bearable and less finicky.
Funny is that near every male customer and wife included wanted to see the porn right as we where showing the system operating. The sports and MTV was a big thing too.Back then they were only about 10 or so that carried TV signals that you could receive on those giant dishes.
Oh this is going back to the very beginning of satellite gear for consumer use. Way before Starlink stuff came out. Like early 80s for sure at least.That was the Starlink stuff or predecessors, tho?
That is some amazing technology and it really amazes me that people come up with these concepts and bring it to market.Supposedly the dishes are "lighting proof" and also heat up in the event of snow. A large thunderstorm with heavy rain and cloud coverage will interrupt throughput though.
@Doodski the dishes don't physically move, but use phased-array tech to connect to the geostationary satellites.
JSmith
I remember...LoL.I had the Playboy channel for a couple of months. It wasn't that great. Bad movies but nice scenery.
I set up the sat link for my parents a while ago and it was an simple as tossing it on the roof and letting it figure things out. No physical adjustment by me at all. The app shows a small sight line blockage from trees but they've never had it cut out for more than a second before readjusting to a new receiving satellite. It's pretty darn easy.Very very nice. That sure beats the days of using a compass, level, home made angle of the dangle meter and compound angle ready rod and bolt adjustments.
Absolutely amazing. Until just minutes ago I had no idea about this new dish and electronics technology. Really nice stuff and the expense is really decent too./I set up the sat link for my parents a while ago and it was an simple as tossing it on the roof and letting it figure things out. No physical adjustment by me at all. The app shows a small sight line blockage from trees but they've never had it cut out for more than a second before readjusting to a new receiving satellite. It's pretty darn easy.
