Static noise from headphone tube amp (Decware Taboo MKIII)
Nobunaga
switzerland
Hey
I just set up my new headphone amp and it works, i can listen to the music but i hear a static noise too a sort of buzz/brrrrrr noise.
Any ideas?
I am using my Asus Essence STX soundcard as dac.
Best regards
RayDunzl
Central Scrutinizer
Riverview FL
watchnerd
Seattle Area, USA
Hey
Any ideas?
Best regards
Damn, that's a really gorgeous headphone amp.
What headphones are you using?
Re: your problem
What happens if you plug in another source, say the output from the headphone jack of your phone? Or anything else you might have that outputs analog?
airofu
Hey
Any ideas?
Best regards
If you disconnect the STX card does the buzz stop? I had that, was a ground loop via my PC, used a cheap USB isolator from ebay and fixed it.
