Steelseries GameDAC?
Doodski
Have you considered this EVGA NU audio card?
https://www.amazon.com/EVGA-Audio-712-P1-AN01-KR-Lifelike-Designed/dp/B07MSQJ3GY?th=1
https://www.evga.com/articles/01281/evga-nu-audio/
https://www.audiosciencereview.com/...d-measurements-of-evga-nu-audio-pc-card.9137/
R
redbert
Doodski
I found the DAC but it measures worse than the one you picked out and it's also USB-C
YSC
yea, this E1DA one is really a surprise, measurement wise it is the top notch where lots of desktop dacs can't achieve, although I believe functionality, power etc. is much worse but if solely for portable laptop use it should be a very good deal, especially considering the price
Doodski
I suggest you see what the peeps that have been here for some time have say about this. When they come online they will probably give you their opinions.
YSC
I will look forward to this but recently spend big time on the Holo Audio Spring 2 Level 2 as my end game dac I am stable for a very long time, last time purchase was a very bad audio -gd NFB1 together with a Auralic Taurus Mk II amp and a Hifiman HE-500 headphone before I got married in 2014. replacing the last broken chain makes me very happy
Celty
Has anyone try or test the Steelseries GameDAC (https://steelseries.com/gaming-accessories/gamedac#specs). I am looking for a small DAC. That one is nice because I can do EQ and see the source info on the screen. Thanks
I own it. It has some fun "gaming" features and does control the RGB on the SteelSeries Pro headphone. It's not terrible but cannot hold a candle to a decent DAC and Amp. The same holds true for "Sound Cards", do yourself a favor and get a legitimate audio solution. Your ears will appreciate it.
R
redbert
OK. Good to know. I will look somewhere else then. I like something that can use the built in eq on the SoC. However, not many solution provides that at affordable price. It is probably because they need a separate general purpose SoC and some software. Maybe I should build my own Pi solution and get the ApplePi DAC board as recommended in this forum.
