Strange effect with a particular IEM
eeeper
Background:
In the last two years I've collected a few IEMs and three over the ear headphones running through a couple sources, on my laptop I use a topping d50 and a l30 headphone amp. I love switching between them (IEMS,headphones) to enjoy different music genres, plus its just fun.
Problem:
Got a mystery box purchase, a bgvp vg4. Decent enough but never really used it much so when I found it in my "extras" box a few days ago and gave it whirl. Within a minute I began feeling nausea and sick. Took them out then went and laid down to relax as I was starting to feel panic rising. I thought it might be a coincidence and ignored it could be IEM related.
Then I tried them again yesterday. Same thing happened. I tried eq'ing it to see if it was a frequency range causing issues because I'm a little treble sensitive but had to stop my investigation because breakfast started knocking on the door to get out.
Doesn't happen on any other IEM I have, cheap or expensive, or headphone. Same source I listen to day in and day out with no issues.
Any thoughts on why this is happening? I'm baffled.
_thelaughingman
Some sort of psychosomatic response to music you're listening. My wife hates repetitive beats and gets nausea and anxiety from dance music.
dc655321
Perhaps the iems are wired out of phase.
Search for pink noise test tracks, one of which is correlated noise, the other decorrelated.
The former should provide a centered acoustic image, the latter should image very wide.
If my hypothesis is correct, the correlated noise track should sound like the decorrelated track...
E
eeeper
I was playing the same song to see the difference between iems. That's why I'm puzzled.
E
eeeper
I'll give it a try when I'm done with work.
