Studio Monitor Calibration
KikoKentaurus
Klaipeda, LTU
Hello there, I have a question.
I'm going to calibrate my Kali-Audio LP6 in an acoustically treated room. I will use -20 dB rms pink noise. How I imagine this process - I will place SPL-meter on a "sweet-spot", and then calibrate every monitor individually to -83 dB.
My audio-interface is Audient EVO 4, it has digital controls. So when I turn up the volume on my interface, it automatically turns up on my computer.
So, the question is: how loud should I set the volume in my interface before I start calibrating volume on my speakers? 50%? 80%? How much headroom do I need?
Thanks in advance.
Matias
São Paulo, Brazil
KikoKentaurus
KikoKentaurus
Klaipeda, LTU
I know him. Thank you. I don't think he's answering exactly my question. My question is about how loud should I set my audio-interface. He's discussing some general techinques which I already know.
p.s. Also, I'm not going to use REW, I like sonarworks muchm more for its simple and easy process.
p.s.s. The problem is that I cannot find any objective degreeing for the volume controls of EVO 4... My knowledge are vast but segmental. This piece of mosaic is hiding somewhere :D
AurekV
I have a pair of Kali LP-8s and I would imagine your main concern would be the self noise of your LP-6s. I would try and set the LP-6s to the lowest gain possible (that gives them the lowest self noise) while still being able to get them loud enough with your audio interface. Then set your reference level with the audio interface volume control.
Practically this should net you the best distortion and S/N possible as your audio interface is almost certainly lower distortion at higher output levels.
AurekV
Practically this should net you the best distortion and S/N possible as your audio interface is almost certainly is lower distortion at higher output levels.
KikoKentaurus
KikoKentaurus
Klaipeda, LTU
Sounds good to me, thank you ;)
