After dialing in the Neumann speakers with my subs I played through some familiar repertoire. *Subjective opinion warning* What struck me right away was how familiar two neutral loudspeakers can sound at first glance (impulse?) despite the room curves being quite dissimilar above the transition frequency. Another proof that room curves are by no means an indicator of sound quality (above the transition frequency).
Since comparing speakers back to back - let's say it takes me a good 10 min to switch setups with everything dialed in - is downright non-reliable I'll refrain from making too much comparison notes. The Neumanns are in a way impressively unimpressive - meaning I can't find anything wrong tonally. They sound as good as their measurements indicate, have excellent power handling for what is essentially a tiny woofer,, and are built quite excellent. These sound clean all the way up to when the clip light starts blinking. with the exception of short, strong, bass impulses, on which I could hear some artifacts (almost a small buzz - perhaps something internal in the speakers) before any protection system was activad, but was unable to find the source. The control app works very well, although I find it clumsy that you can't enter values by means of keypad, but have to use the little sliders to set everything. Also you have to use an additional network swtich and connect everything by cables - a bluetooth option would have been nice. All in all for +/-€400 ($500 in the US) a piece, this is an excellent compact loudspeaker. Don't use these without subs though - you'll lose a lot of potential.
If I have to point out something negative, it's that perhaps they sounds slightly less 'live' than the Revels - this is hard to describe without going using subjective terms, but I feel this has to do with the dispersion pattern of the Revels being wider - depending on the content played I feel this is noticeable, and desirable. Conclusion: if you're in the market for a compact, active, satelite speaker with a good set of options, and are not expecting cinema reference sound levels, these should be on your list along with perhaps some Genelec offerings.
