Subwoofer hum ground loop issue?
suttondesign
Bellingham, WA
I recently started to notice a hum from my Rythmik E15HP subwoofer. It's not loud enough to notice while listening but loud enough to be annoying when the room is quiet.
Based on my research this is a biproduct of using a separate circuit for AV equipment and separate circuit for the subwoofer. That is the differing ground potentials may create a ground loop in an unbalanced connection. So the only solution would be to use some device to lift the ground or use a balanced connection. So perhaps an Emotiva CMX-2 might do this in a safer way which some have recommended. The subwoofer is in the back of the room my options are limited in plugging everything into a single circuit.
Anything I can do besides trying a device that was mentioned earlier? I'd like to tackle and resolve this issue.
suttondesign
Bellingham, WA
I had the same problem and got the Emotiva dc offset eliminator. Completely eliminated the buzz. Totally worth it.
Corock
This looks like it has some kind of headphone jack inputs? I'm guessing there are different versions with RCA connections.
just need the right cable
T
thepiecesfit
Hum, no pun intended, sub hum is routinely found to be caused by the Cable Box, Satellite Box. You can try to disconnect the internet lan connection from the AVR if your using this hard wire connection. It could be the cable modem?
Question. You have a cable modem but no cable tv?
Yes correct. Don't use ethernet to the AVR only WiFi for some Heos streaming. The hum disappears if I disconnect the surge protector and AV equipment in front of the room. The sub is in the back of the room on a different circuit. But frankly anything plugged back into that front wall introduces the hum again. So it doesn't seem like any one device is responsible, but rather a combination of both.
Lambda
Very Methodical trouble shooting is needed.
what is the minimal setup that creates the problem? just AVR connected to the sub and power?
pjug
Surely this is a ground loop as OP suspects. Just get a cheap isolator from Amazon, BestBuy, whatever and you can confirm this. Then if you want a better one or decide to run a balanced cable, you can take it from there.
raindance
Doesn't matter how you fake a balanced connection with wiring, it remains single ended and the ground loop remains. You have to generate the other half of the balanced signal at the source.
Lambda
No.
if the receiver is a proper differential amplifier this is totally sufficient!
Cold = Noise
Hot = Signals + Noise
The receiver Amplifies the differential. aka Hot-Cold=signal=
(Signal + Noise)-(Noise)= Signal
Speedskater
Cleveland, Ohio USA
Actually you could make a RCA to XLR adapter similar to the one in post #11 and install it at the sub-woofer end of the coax cable.
Just don't attach the shield to the RCA connector.
pjug
I agree a pseudo-balanced solution should break the ground loop, but won't you need to wrap a shield around the cable with the XLR ground connection in a long cable run? So I can't see how this can really be a good solution with the existing coax in the wall.
Speedskater
Cleveland, Ohio USA
The coax shield will remain attached at the RCA send end.
In pro XLR balanced interconnect systems, sometimes the shield is only connected at the send end.
pjug
But if you use the RCA outer conductor as part of differential input of XLR then that conductor needs shielding, no?
raindance
No.
Cold = Noise
Interesting! So what are the chances that the sub has a differential input stage?
pjug
That is a good question. Personally I would just buy the Jensen subwoofer isolation thing. Looks like it will be transparent if you look at the specs and graphs.
