Subwoofer Monoprice 10in Powered Studio
ModDIY
Hi all,
Small feedback on the Monoprice 10in Powered Studio subwoofer. Right out of the box, I got a good impression. The finish considering the price is excellent, no apparent cosmetic defect.
After several attempts to adjust, I set the volume between -26 to -24db. The lowest is -30db. The reason I have to attenuate so low is that the preamplifier is a gainless buffer that feeds the 2 stereo amps for the speakers. I adjusted the cutoff frequency to around 60hz.
The first listenings with jazz which has good bass I liked straight away. Then I switched to classical music. With small ensembles, chamber music, trio or solo piano style for example, we can more easily detect whether the bass goes well with the speakers. And it is, I am pleasantly surprised.
I consider that I made a good choice. So yes it is quite musical and if we adjust it correctly with quality speakers, you will also agree with me. An excellent listening test would be to put it with small bookshelf style studio monitors, because it is designed for that with these XLR and 1/4 "outputs. Please note it does not have an LFE input to connect with an amplifier CM. In addition it has a 1/4 "jack for connecting a pedal (Fender at $ 25 on Amazon or other) which allows you to deactivate the sub and send all the bass to the monitoring monitors, it is convenient in a small studio to check its mix without the sub, in my case it doesn't help me, but I wanted to mention it.
The subwoofer has a 200w RMS class AB amplifier. Haven't tested with super high volume yet, let's say I didn't buy it for that.
https://www.monoprice.com/product?p_id=605999
ModDIY
ModDIY
Hi,
for my part with my column speakers finished, after several measurements with a microphone, the subwoofer is very transparent and does its job well. I'm quite picky, the subwoofer has become essential for me, because before I had bigger columns with 10 "woofers, but I wanted to decrease the footprint in the living room, I had doubts at the beginning but can now.
By the way, you shouldn't expect a 20-25hz f3, these are not the Monolith series, but according to measurements and what I had before with my old columns (27hz f3), the subwoofers easily reproduced at 35hz.
mssngpeces
Do the XLR/TRS outputs act as a variable High Pass Filter? Seems like this is what the user guide states, but some people are saying it's an error and they output a full range signal.
ModDIY
ModDIY
I don't use the xover output, because I connect my direct XLR DAC in the subwoofer and the direct RCA output in my 2 amplifiers for the fullrange columns.
I doubt that is true.
There is a 1/4 to add a pedal and bypass the sub and send all the bass to the monitors.
I doubt Monoprice could have made such a mistake. One buyer mentioned that he put on a Fender pedal and that it works fine.
ModDIY
ModDIY
Okay I read too fast, you mean in the precision of the cutoff frequency of what is sent to the monitors?!?
I wonder if it does not partly depend on the input impedance of the monitors, which could affect the cutoff frequency.
