Synthesis Waveforms and Harmonics - How do they work?
NoiseyParker
Hello,
I am currently studying sound synthesis and I am totally fascinated. However, I don't full understand the harmonics of different oscillators? I understand that a triangle wave has the odd harmonics present and that every other is in reverse polarity, but I don't understand why? It seems relatively close in shape to a saw tooth wave that has all the harmonics? I understand that a square wave has only the odd harmonics present, but not sure why? Can any one help me or point me towards a good source?
Many thanks
It can be shown by expanding the fourier series. In that regard, there is infinite number of harmonics. It is just that for a square wave, half the coefficients become zero and those are the even ones.
An intuitive way to think about this is that a sine wave is in phase with a square wave. In other words, it is like a square wave but its corners have been rounded. A cosine term on the other hand (representing the even terms) would be inverse phase of the square wave so can't exist in that expansion.
Here is a good video that shows this but by necessity, is full of math: https://www.khanacademy.org/science...ies/v/ee-fourier-coefficients-for-square-wave
N
NoiseyParker
OK so that video is beyond my level of knowledge, but I think I understand that half the coefficients are zero (because the signal is essentially on and off at a regular pulse?) But I don't understand the triangle wave - why are every other at reverse polarity?
RayDunzl
Central Scrutinizer
Riverview FL
By definition?
It's how the value of the amplitude of the series - where you have a sine fundamental, the odd multiples of that frequency, with the value of 1/number_of_the_harmonic times the fundamental amplitude "adds up".
Audacity (or other software) will allow you to build waveforms by combining tracks.
