Talk about my recent use of IEM
Let me share my iems uesd usually including Tangzu WanEr, KZ linglong, CCA CXS, Moondrop chu and 7Hz zero before I often listen by Moondrop chu. They sounded nice but noise was obvious and lacked of bass. However, it was unimaginable that they were gone just used and less than half of year. Yep, I cannot stand that, how the quality is bad! Although they're so cheap but man I don't want to buy rubbish though they’re blow $20. The full metal iems are into my taste, and which are the earphones you guys use the most?
IAtaman
You had a number of IEMs, such as Wan'eer, 7Hz Zero, CCA CXS, Chu etc. Your favourite was Chu. However it broke down after 6 months. Now you are only interested in metal shell IEMs and are asking for recommendations. Is that correct?
JermarioAnderson
Yes, any recommendations?
mrbungle
Boston
Moondrop Kato? FiiO and Dunu have a relatively wide selection across different price points. Tin HiFi T4. S12Pro. So many options.
markanini
Scania
Moondrop Lan has the metal shells in the shape the Chu. I recommend the Lan.
