- Joined
- Aug 21, 2020
- Messages
- 2,741
- Likes
- 5,819
Yes it does. Above room transition frequency we mainly perceive tonality from the direct sound which thus should be flat, so if the window would be so short that it would only catch the direct sound and not its reflections the measurement would be flat without sounding harsh. Thus in typical rooms for correction in that region some anechoic loudspeaker measurements are more helpful than a measurements at the listening position where the gap after the reflections is too short for a large enough window.
Some good reading material on the topic:
https://www.aes.org/e-lib/browse.cfm?elib=17839 (free download)
Some comments from Floyd Toole about room curve targets, room EQ and more
Room curve targets Every so often it is good to review what we know about room curves, targets, etc. Almost 50 years of double-blind listening tests have shown persuasively that listeners like loudspeakers with flat, smooth, anechoic on-axis and listening-window frequency responses. Those with...www.audiosciencereview.com
I'm not sure how this contributes to the discussion. No one has contested that a speaker should be anechoically flat above a typical transition frequency.
