Tascam 102i Review (Audio Interface)
This is a review and detailed measurements of the Tascam 102i Audio Interface (DAC, ADC and headphone amplifier). It is on kind loan from a member and costs US $399.
I like the departure from usual designs by having the unit tilted up some:
Here is the back side (I put spacers under it to make it easier to take the picture):
The DAC output was surprisingly poor with stock class driver. I downloaded the image from Tascam which remedied that. Download speed was quite slow though. They need to host this someplace better. Once there, I lost all output. :( Had to figure out the cryptic routing UI to turn the computer output back on for each channel.
Note that my testing is focused on performance in specific areas. I am not testing functionality of these interfaces.
Tascam 102i DAC Measurements
As always, we start with our DAC output with volume adjusted to 4 volts out:
Not something to write home about but not broken either:
Letting the output swing out more doesn't get you better performance:
Dynamic range is similar:
IMD test shows surprisingly high level of noise when the signal is low:
Jitter suppression is good but there could be bad stuff buried in higher than wanted noise level:
The filter is unfortunately the typical, incorrect one:
While this is very common, I wish at least pro products implement this correctly with faster cut off.
Linearity could be better:
Last test was quite a puzzler at first:
Surely we don't have half a percent noise and distortion! Let's find out the cause:
This is the typical noise shaping we used to see in older DAC chips. Noise in the audible band is reduced by pushing it into ultrasonics. Native performance needs to be a lot better so this is not needed or at least not needed to this degree.
Finally multitone shows that higher frequencies produce more distortion:
Tascam 102i ADC Measurements
Here is our dashboard:
Pretty disappointing performance:
Distortion is the problem. Noise is much better:
Linearity is not great:
The high distortion seems to be frequency independent:
Tascam 102i Headphone Measurements
Here is our dashboard with volume adjusted for 4 volt out:
Not bad. Let's load it down to 300 ohm and see what we get:
Very strange response. Not sure what is going on. Maybe it has a dual stage buffer or something? Regardless, we have OK amount of power.
Switching to 33 ohm causes the power to drop way down:
Suspecting that it is due to high output impedance and I measured it at 85 ohm. This some of the highest I have ever measured and falls in the category of truly awful! You not only lose a lot of power but the frequency response of the headphone can change resulting in tonality variations.
Performance of the DAC in Tascam 102i is reasonable. ADC however can't even clear the 16 bit hurdle with 4 volts in. Headphone amplifier is just junk with high output impedance.
Based on performance measurements I perform, I can't recommend the Tascam 102i. For a current product, it simply is not very competitive.
Man these interfaces take a ton of work to measure. So many subsystems. My fingers are hurting!!!
Koeitje
The channel balance seems to be off for the DAC part?
phoenixsong
restorer-john
I've noticed those audiophile spacers in a few of your recent shots. Clearly you have also found the benefits of critical elevation in reducing surface interference and promoting more "air" and "separation".
Did you get yours off the top of first press, extra virgin olive oil containers like I did? ;)
daftcombo
Nice review again, thanks a lot!
In the same vein, MOTU and Focusrite Scarlett seem a bit cheaper and better.
PeteL
If at least it was competitive in price... It's more than twice as much as the competition and not half as good. What's going on here, Tascam is not known to be overpriced and have been there forever with relatively high volume target, more semi pro than full fledge studio stuff. The discontinued UH 7000 is about 10 years old with the same functionality but still is today miles better. I still use mine today and from experience, very poor customer support, drivers writing was not their strong suit neither, very late each time for OS compatibility, but when it works it performs, this here is just embarrassing from a company that mature.
Vict0r
The Netherlands
Ouch. At least the case looks nice, right? I'll stick with my Motu M4. :)
Thanks for the review!!
restorer-john
Very comprehensive review @amirm
The A/D - D/A reviews are most illuminating as there are many members who use these devices for measurement, not just recording their garage band. I know they take twice as much work, but it's worth it.
Paco De Lucia
Motu all the way. (20 years experience)
Ron Texas
Thank you for another review @amirm This product really isn't aimed at hi-fi although it appears those making audio recordings could do better for $400.
dtaylo1066
I am thinking you and Amir have conspired to corner the market with these new "audio spacers" that are silicon-gel-based but with added virgin olive oil and other proprietary additives. Smart move and I am pissed you beat me to it. I suggest you call them GELS. Gelatin Enhanced Levels of SINAD. Brilliant.
GWolfman
Does this mean it's possible they just tapped one of the line outs for the headphones ?
rdenney
Back in Tascam’s heyday, this would have been outstanding performance.
Time passes.
Rick “fine for live field recording, perhaps, but thinking my Presonus Studio 24C is better for that and much cheaper” Denney
