Technics SL 1210GR2 Turntable
Bob from Florida
Bob from Florida
Thank you for the summary.
I have a Technics SL-M3 and am not a Fremer fan. Usually, if I read anything by him or about him, it is accidental
I was hoping to get the wow & flutter spec (or measurements) without paying Fremer's site a visit.
As everything else that I was interested in was in the Stereo Review article.
Just so (you, in case you did not) & others know the specs on the unusual SL-M3, I'll post them here:
Technics SL-M3​
Quartz Controlled Direct-Drive Fully-Automatic Turntable System (1984-1988)
with linear tracking tonearm
Technics SL-M3
Specifications​
Type: fully automatic
Drive method: direct drive
Motor: brushless DC motor
Drive control method: quartz phase locked control
Platter: 325mm, 2.5kg, aluminum die-cast
Pitch control: +-6% range
Speeds: 33 and 45rpm
Wow and flutter: 0.022% WRMS
Rumble: -82dB
Tonearm: dynamically-balanced linear tracking
Effective length: 238mm
Effective mass: 13g (including cartridge)
Cartridge: moving magnet
Replacement stylus: EPS-33ES
Dimensions: 526 x 205 x 425mm
Weight: 15kg
That looks like a “fancy living” turntable! Being functional after all these years is a testament to its engineering.
Reactions: EJ3
EJ3
James Island, SC
It has been refurbished about 10 years ago & since then I have replaced the drive belt to the linear tracking arm.
I also have a refurbished DUAL 1229 with an American walnut plinth that I gave as a gift to my mother for her system.
She has it in almost daily use several hours a day, playing mostly LP's of Austrian & German Folk songs (she is a WWII survivor from Salzburg, Austria).
My SL-M3 is not in use quite that extensively but it is in use a lot (usually with a SHURE V-15 ULTRA 300 or one of the other V-15 P-Mount variations [occasionally with a NOS Technic's original cartridge]).
It seems adequate for every day use. (I started out in the mid-late 70's with a Connoisseur BD-2, a Grace tonearm & whatever the TOTL SHURE cart was at the time).
Here is a pretty good video on one:
anmpr1
To bad you have to go to Fremer and Tracking Angle to find the wow&flutter measurememts…
Back in the day, Ed Long (writing for Audio magazine) provided some of the best analytical data on record players. I recently reread his SP-10 Mk3 review, a deck which at the time was considered best of the best of Technics DD players. Surprisingly (at least to me) Long reported that it ran 'fast' at its quartz locked nominal speed:
Figure 3 shows the spectrum due to playing a recorded 3,150-Hz tone and indicates that the SP-10MK3 is running slightly fast in the 33.3 rpm quartz-locked mode. This is shown as +0.19% in "Measured Data." What this means is that a record which should be exactly 60 minutes when played at 33.3 rpm, will take 59 minutes and 53.2 seconds. This is excellent long-term stability and could be made almost perfect by setting the speed back two clicks to -0.2%.
For comparison, below are two charts, representative of two contemporary players. First for the SP-10 Mk3 ($1800.00 for player, $900.00 for optional base), the second for a top tier belt drive-- the SOTA Star Sapphire ($1600.00) player featuring vacuum record hold down.
EJ3
James Island, SC
View attachment 358734 View attachment 358735
I suspect that would be pretty hard to notice for most people listening to one side of an LP & then turning it over to listen to the other side.
Perhaps some drummer's might be better than he average person at catching that.
JP
Brookfield, CT
Consider the signal being measured.
mike70
maybe the top belt drive compete with the Technics in speed accuracy (until the belt stretches) but ... in mid / low tier budget (where the 99.9% of users are) what's the reality with similar products?
anmpr1
Probably impossible to tell. Without a stopwatch. Especially considering all the other stuff going on with LPs-- off center records, mistracking, lateral tracking error and so forth.
Ed Long kind of throws out a somewhat misleading factoid in his write-up. He offers a figure for a 60 minute record, which is quite rare, and in any case has no practical relation to what about 100% of listeners encounter.
Recall how over 60 minutes the uncorrected lag on his example was 7 seconds. That's 3.5 seconds for one side (which is all anyone ever listens to at a time); it's difficult to even encounter a thirty minute LP side. I know some of the 'historic' Furtwangler LPs had upwards of 45 minutes a side, and Todd Rundgren liked to compress a lot of music into a short run of plastic. However with those, the sonic quality of compression was what listeners noticed, and not timing, per se. So realistically listeners would be behind about 2.3 seconds for a 20 minute side.
For me, what is more interesting than any of that was how the then world's most expensive Quartz PLL DD turntable (as far as I know--and if not the most expensive, at least it was the most well-known) had that much variance. In locked mode my SL-1200 Mk5 runs about 33.5 RPM (measured using one of the popular Android apps). Whether and how much those phone apps reflect rotational reality is something I can't discuss.
morillon
this also modifies the pitch of the sound and not only the speed of execution....
(apart from "karaoke" conditions which could be the most demanding... it seems to me that professional musicians will point out to you the fact that it becomes sensitive if we go to more than 0.1% (0.03tr)... (but the w&f is worse.... logical ..))
JP
Brookfield, CT
It doesn't, and again, consider the measurement signal.
morillon
telephone applications can really pose a problem,... but 33.5tr would just be unthinkable for this type of machine it seems to me... you should check with other approaches
(It is conceivable, and regrettable, with mains frequency turntables because, at least in my country, even if by sliding not too fast, and mains current is at +-0.1% in frequency ....but on regulated DC turntables etc would seem a little incongruous..)
mike70
Bet for Technics night and day ... since the first 1200s in the end of 70s, they're over many and many negative marketing all the time.
And they become a classic, not only as DJ machine because the high reliability, construction and flexibility enable it, but as a great table in general.
Bring me a really better table at the same price tag in the different 1200s "flavours", from the mk7 to the G, and we talk about it.
I'm a fan? Yes ... after using a Mk2 in the eighties, read all the "audiophile" press had to say and listening to some of the holy cows. They deserve it.
