The best headphone for EQ
WickedInsignia
Australia
Here at ASR we're pretty EQ-crazy. That's perfectly valid, since EQ is just another link on the chain to make music sound more natural and enjoyable.
So what is the best "EQ-ready" headphone?
If we consider some notes Oratory1990 has made on this topic (excerpt from this comment), we gain an idea of what makes a headphone a great platform for EQ:
  1. Perform reliably, with repeatable seal across multiple users.
  2. Easily obtain the amount of seal that it was designed for (rip glasses users or people with large beards).
  3. Have good quality control = little unit variation and no channel imbalance.
  4. Have a relatively smooth FR free from high-q artifacts (sharp peaks and dips).
  5. Deform the pinna as little as possible.
  6. Have little reflections inside the earcup, especially those that lead to destructive interference. You can't fix a notch in the FR with EQ (non-flat excess group delay).
  7. Have suitably low distortion.
This is more about identifying headphones that act as a good platform for EQ, regardless of how they sound at stock (within reason, since adhesion to the preference target makes less adjustments necessary). Which headphone/s satisfy much of this criteria, have proven the most receptive to EQ, and could become an amazing performer with a tune-up?
Consider price/performance ratio!
staticV3
IEMs tick so many boxes, it would be a shame to disregard them.
WickedInsignia
WickedInsignia
Australia
Including them would cause some dissonance in conversation since the logistics between both wearing types are quite different, as well as the preference targets. Keeping it to headphones for the sake of simplicity, but you’re welcome to make a similar thread for IEMs!
Colonel Bogey
Stockholm, Sweden
BUMP
Any specific suggestions to OPs very relevant question? I'm struggling with that issue right now - got my Qudelix 5K yesterday and need to buy cans to go with it for use in my office (needs to be open). HD 600 is an obvious candidate, significantly cheaper than 650 over here but are there other options for a low distortion, smooth and EQ-able FR open headphones? I would be willing to spend significantly more is there is a tangible SQ improvement. And yes, I quite like the Harman curve;-)
someguyontheinternet
Germany
For open headphones I think Audeze makes some good stuff. The more recent models also seem to come with more reasonable weight than their other models.
For closed there is the obvious choice of DCA Stealth.
MayaTlab
One limitation of the HD6... series is that the FR above 3kHz or so may vary quite a bit because of pads ageing / sample variation / individual coupling. Below 100Hz there may also be a bit of sample variation according to Oratory.
My favourite option right now still is a pair of HD650, but with Dekoni Elite Velour pads. The FR is super-consistent and rock solid when moving my head about, and the pads haven't noticeably aged during the last year. But that combo hasn't been widely measured on industry standard rigs and I use in-ear mics to EQ them.
I'd have been tempted to say a pair of HD800(S) might fit quite a few of the criterion above, but as far as I'm concerned it's a design that moves about far too easily on my head.
I'd add to the list above :
- pads that either don't age much over time, or are as inconsequential as possible to the overall SQ
- few coupling issues in general (it isn't just leakage)
Germany
It seems not that different from previous DCA headphones in terms of potential leakage issues, so that might not fit point n°2 above.
I don't know where the leakage assumptions stems from, but I also don't have solid data on it.
What I know is that my head is on the small side of the average size based on hat sizes. Size 56-57cm (around 22 inches) fits me perfectly. I also wear glasses.
I cannot report any significant leaking issues while using the Aeon RT or Stealth. The only issue of that category I had was with longer hair which had to be moved out of the way to allow proper contact between pads and my skin.
Based on this information I would assume that most adult males would have little to no issues getting a good seal unless they have a large beard or don't bother to move longer hair out of the way.
FrantzM
Hi
Interesting thread.
I would assume that headphones with intrinsically low THD across their passband would be the principal candidates. From memory an Audeze whose exact model I forgot, and the HifiMan HE6SE any version were either the best or among the top 5.
Currently one can find the HifiMan HE6Sev2 at $400.oo at Adorama. Caveat: The tales of poor Quality Control and DOA are real, or at least were to me. In my personal case, a call to HiMan and I had a new, in-the box model shipped next day... I have had this headphones for almost a year and.. , this is by far the best headphones I have heard after EQ. I like the Harman curve and EQ-ed the HE-6SE to this target.. it can take it.. It does, however, require a powerful amplifier. I use a Drop THX 879 and the Topping D10B DAC.. I believe I have a listening chain with a total SINAD around 75 dB... This is as good as its gets... It is extremely difficult to do better... No EQ, the HE6Se is meh, after.... Difficult to put in words the quality of reproduction.... SOTA. I wear glasses and it seems to me that planars do not require a perfect or even good seal to provide excellent performance.. Nor do they need any particular clamping force. You put them on and they perform, consistently. The He6Sev2 is heavy, this doesn't bother me one bit.
Happy holidays!
Peace.
_thelaughingman
I think Audeze LCD2F are what come to mind as being the headphones that can handle EQ really well.
concorde1
Yeah I used to have an LCD-2F; if I recall correctly it sounded great with EQ.
Then I switched to LCD-3F and I can't get any EQ right for it. At times I've thought I have a good EQ but no I'm never happy with it long term.
Is the LCD-2F unit variation supposedly low? I might get another LCD-2F. Or something else like HD800S.
_thelaughingman
I haven't heard or seen evidence of unit variation for the LCD-2F, but it's always a possibility.
Elitzur–Vaidman
I'd have to send them in to amirm for measurement (I'd be happy to do so), but I think the Sony MDR Z7M2 might just be the best headphone for EQ. The pads are shaped to give a pretty much perfect seal and the comfort can't be beat imo. My only concern is that a 3" dynamic driver might inherently have some higher frequency distortion.
staticV3
@Elitzur–Vaidman the Z7M2 is like the opposite of EQ friendly. Look at that chewed up pinna gain:
