AwesomeSauce2015
- Joined
- Apr 14, 2022
- Messages
- 209
- Likes
- 199
Sort of, I was mainly referring to the "almighty" SINAD measurement. Most pro amps measured here have much worse SINAD measurements than most "home" amplifiers. Additionally, most home amps are designed for use in the same room as the speakers, and so don't have loud fans (or fans at all).Many pro amps are on par with their shiny residential brothers. If residual noise is an issue you buy a plenty powerful amp and use the attenuators. Easy peasy.
Now, in a professional use case, where the amps may be on 24/7 in a rack with a bunch of other amps, having powerful fans, and worse SINAD in exchange for power and reliability are good trades. But in a domestic environment, these trades may not be as desirable.
Looking through the list of amps, here are my thoughts:
Crown DCi 4|1250:
No DSP, and this is a 70/100V amplifier and I wouldn't recommend it for a non-70/100V system, just because that capability will cost you more and be wasted. There are other, better options from Crown if you for some reason need this power output.
QSC DCA 3422:
No DSP as well, This is a 2 channel amplifier and you want 4 channels. Also, the output terminals seem to be only Speakon, which may be annoying.
Dynacord IPX 10:4:
Good luck wiring to this thing. The IO terminals, and the power cable port are not "normal". This is a 4 channel DSP amplifier, so it meets your criteria. No idea about the price though.
Powersoft Quattrocanali 2404:
Same comment about the wiring as above. This also looks to be a 4 channel DSP amplifier, and given the form factor, and the fact that it is EN54 compliant (ie, fire alarms, life safety), it is probably going to be expensive.
So like I said above, it really comes down to what you want to do with the amp. Without knowing your use case, I can't really make any recommendations. All I can say is that Crown and QSC are good brands, with reasonable prices, Crown makes DSP amplifiers, no idea for QSC.
